D15b vtec engine harness
Old Jun 1, 2005 | 07:47 PM
Galaxy Si's Avatar
Default D15b vtec engine harness
i have everything i need for the swap, but just one thing troubles me. what engine harness do i use, or what modifications do i make to my current harness for it to run properly with vtec. i searched, but no for sure answer
Old Jun 2, 2005 | 02:05 AM
longbeachpurplecivic's Avatar
Default Re: D15b vtec engine harness (B18C1 Del Sol soon)
my cousin tossed in a d15b V and he used the d16z6 harness
Old Jun 2, 2005 | 02:07 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: D15b vtec engine harness (longbeachpurplecivic)
depends on what engine harness you plan on using with what motor/car. if yoru car is already not pre-wired for vtec you'll have to wire up the 2 wires to the ecu.
Old Jun 2, 2005 | 06:29 AM
Galaxy Si's Avatar
Default Re: D15b vtec engine harness (AzntaggeR)
its going into a 95' Del Sol and it currently has a d15b7 in it. so i should just use my current harness and then route two wires that connect the ecu to the vtec solenoid
Old Jun 2, 2005 | 06:49 AM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1 Del Sol soon &raquo;</TD></TR><TR><TD CLASS="quote">its going into a 95' Del Sol and it currently has a d15b7 in it. so i should just use my current harness and then route two wires that connect the ecu to the vtec solenoid</TD></TR></TABLE>
Bingo
gzes
Dec 23, 2012 01:09 PM
aalouie
May 30, 2012 05:58 PM
Mr. Roboto
Dec 10, 2006 06:59 PM
HaNsElBaDaSs
Oct 19, 2006 11:17 AM
Lmgrcivic
Jan 15, 2005 03:34 PM
