Suspension & Brakes Theory, alignment, spring rates....
Need help with GC Top-hats install w/Illuminas
Old Jun 1, 2005 | 05:14 PM
AlphaQup's Avatar
Default Need help with GC Top-hats install w/Illuminas
I'm lookin to install my GC top-hats with my current Illuminas. The dilemma I encountered was this:
How am I suppose to take the illuminas off the OEM tophats? I know that for the stock struts, you can use an allen wrench and hold the rod while you turn the nut with a wrench. With the Illuminas, there is no allen wrench insert at the tip of the strut rod. That's where the dial is to change the strut settings . (Can you take that little red dial off? Is the allen wrench insert, under the dial?)
Some might say use an impact gun, but all I have are handtools. If anybody has done this before, please let me know. I'm not in no hurry to swap these in, since my car rides fine. I just want to know how to take that nut off of the Illuminas
Old Jun 1, 2005 | 05:20 PM
MattD@Stoptech's Avatar
Default Re: Need help with GC Top-hats install w/Illuminas (AlphaQup)
most top adjustable shocks use a double nut arrangement
Old Jun 1, 2005 | 05:29 PM
AlphaQup's Avatar
Default Re: Need help with GC Top-hats install w/Illuminas (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">most top adjustable shocks use a double nut arrangement</TD></TR></TABLE>
Well, if there were double nuts, I wouldn't be posting .
Single OEM nut was used. I was not the installer of the Illuminas. They were swapped from my old EG, tophats n all.
Old Jun 1, 2005 | 06:28 PM
94eg!'s Avatar
#1 Super Guy
Loved
The top of Koni sports shaft is hexagonal above the threads, so you can use a deep socket to hold it still while you tighten the nuts w/ an open end wrench. Do the Illuminas have anything like that?
Also, have you tried just wrenching on the top nut by itself. Chances are it would just come off. I would think the hard part would be getting it back on. Even if you had a jam nut, it would be just as difficult to remove the second nut once you loosended the 1st one, so I don't think a missing jam nut is your problem...
Good luck...
Old Jun 1, 2005 | 09:19 PM
Tyson's Avatar
Default Re: Need help with GC Top-hats install w/Illuminas (94eg!)
have both of you, 94eg and epd, ever seen a tokico shock before? its not double nutted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">(Can you take that little red dial off? Is the allen wrench insert, under the dial?)</TD></TR></TABLE>
alpha, yeah, take the red adjuster off. just take some pliers and itll come off. you can reuse it. then install like stock shocks.
Old Jun 1, 2005 | 09:33 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Need help with GC Top-hats install w/Illuminas (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">have both of you, 94eg and epd, ever seen a tokico shock before? </TD></TR></TABLE>
No, and I didn't say it was. I stated that even if it were, it would still be just as difficult to remove...
Old Jun 1, 2005 | 09:53 PM
AlphaQup's Avatar
alpha, yeah, take the red adjuster off. just take some pliers and itll come off. you can reuse it. then install like stock shocks. </TD></TR></TABLE>
Thanks Tyson.
Old Jun 1, 2005 | 10:08 PM
EK k kay's Avatar
My 96-00 kyb agx are double nutted on the front and in the rear it has a flat part on the top of the shaft that you can use a set of pliers or vice grips to hold onto while tightening the nut.
Old Jun 2, 2005 | 05:59 PM
Another_EK_Hatch's Avatar
i just did the same exact installation on my EK... u have to take off the little red dial. just use a flat head and pry it off
Its me DUB
26
Apr 4, 2006 11:04 AM
VeilSide_Mas
Feb 7, 2006 01:58 PM
lsvtec101
Suspension & Brakes
Jan 14, 2005 01:03 PM
SOHC_MShue
Aug 28, 2003 09:27 PM
Aahj
Apr 20, 2002 08:06 PM
