obd0 to obd2?
You would have to convert to OBD1 first, then you can get a conversion harness that convert OBD2 to OBD1.
http://www.jkobd.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91B16HF »</TD></TR><TR><TD CLASS="quote">You would have to convert to OBD1 first, then you can get a conversion harness that convert OBD2 to OBD1.
http://www.jkobd.com/</TD></TR></TABLE>
You're smoking crack. OBD0 to OBD2a or 2b, available on the JKOBD.com website.
If you need your harness modified for that engine along with the distributor plug changed, let us know.
http://www.rywire.com
(all OBD2 jumper harnesses are sold directly from JKOBD, Rywire only stocks OBD1 stuff)
the only possible way I see is to get the jumper harness from obd0 to obd1, then take that and then match the wires with an obd1 to obd2 harness
what the hell is he talking about??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster »</TD></TR><TR><TD CLASS="quote">from what i hear a obd2 dizzy will work on a obd1 car. </TD></TR></TABLE>
Yes you can use it.
Yes you can use it.
NOman0608
Jul 26, 2007 10:28 AM
