SOHC Turbo Set Up running hot
Old Jun 1, 2005 | 03:58 PM
MugenT's Avatar
Default SOHC Turbo Set Up running hot
I was wondering if any one can help me with my problem. My car uses a lot of coolant and I was wondering if any can tell me what kind of radiator i should use with the SOHC Turbo. I was gonna use a GSR radiator but I'm not sure because I'm thinking about going with a after market aluminum radiator. What should I go with for my car?
Old Jun 1, 2005 | 04:00 PM
komat's Avatar
Default Re: SOHC Turbo Set Up running hot (MugenT)
what do you mean it uses alot of coolant
the coolaint is missing??
if so you have a blown headgasket
for a better radiator get a del sol vtec dual core
Old Jun 1, 2005 | 04:01 PM
lsvtecracer's Avatar
Usually a dual core radiator from a del sol should be fine, but if you want to go aftermarket then any dual core radiators should be fine.
Old Jun 1, 2005 | 04:23 PM
Street Ghost's Avatar
Default Re: SOHC Turbo Set Up running hot (lsvtecracer)
is it overheating? you probably lifted the head.. which is quite common for boosted d-series. its recommended that your change the headgasket, resurface the head, and install some ARP head studs.
R-Lug's Avatar
Fluidyne Racing Radiator... expect nothing but the best.
Used it when i had the Z6Turbo, needle never even came close to midway point with stock thermostat. The stock radiator blew the top right after the turbo was installed. Highly recommend it
97dc2
Jan 1, 2006 10:03 PM
teamvirus
Dec 17, 2005 08:08 PM
bootlegtrader
Jul 31, 2005 10:54 AM
Vinhtran17
Aug 30, 2004 07:56 PM
bboy_gangsta
14
Sep 17, 2002 10:35 AM
