PortFlow heads with SuperTech valve trains
Available for the B series, D series, H series, K series and S2000 blocks.
Head is disassembled, hot tanked, ported and polished by PortFlow, competition 3 angle valve job, surfaced and reassembled with SuperTech stainless steel nitride coated valves (choice of stock size or .5mm oversized), ST titanium retainers and ST dual valve springs. Price is $1600 with free return shipping.
IM Ninesecrx for any questions...
Check our budget head pricing here:
http://www.laskeyracing.com/shop/portflow.htm
Here are some pix:
Modified by earl at 8:18 PM 5/1/2007
Here are some pix:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg »</TD></TR><TR><TD CLASS="quote">Do you do spotfacing for larger bore then stock? Say going from 81mm to 84.5mm for B18B? Thanks? Pm me with prices please.</TD></TR></TABLE>
Portflow does not spotface.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg »</TD></TR><TR><TD CLASS="quote">Thanks. </TD></TR></TABLE>
Welcome
Welcome
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx »</TD></TR><TR><TD CLASS="quote">
Portflow does not spotface.</TD></TR></TABLE>
My portflow head had the bowls machined to match the cylinder bore (84.5mm), as well as CC'd to ensure that each bowl is identical in volume.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">
My portflow head had the bowls machined to match the cylinder bore (84.5mm), as well as CC'd to ensure that each bowl is identical in volume. </TD></TR></TABLE>
Yes, he can open them up on the sides for whatever size bore you want, but spot faceing is done with a boreing bar all the way around...even where the valves sit which they dont do.
would those ST valve springs & TI retainers be acceptable for using toda spec b or c cams in the F20C(S2000) head??? and what is the turn around time??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project SSAP1 »</TD></TR><TR><TD CLASS="quote">would those ST valve springs & TI retainers be acceptable for using toda spec b or c cams in the F20C(S2000) head??? and what is the turn around time??</TD></TR></TABLE>Absolutely on the SuperTech. I think it is the best components available for the S2000. Turn around time is 1-2 weeks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clint g »</TD></TR><TR><TD CLASS="quote">how long are yall running this promotion? I gotta get my money up</TD></TR></TABLE>
Hurry Hurry Hurry...
It will still be ready when you are
So there's no extra charge for opening the sides for a 84mm or 85 mm piston bore? But what about the valves if I have that 84mm or 85mm bore what sizes valves would I need for this setup oversize or the usual?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clint g »</TD></TR><TR><TD CLASS="quote">So there's no extra charge for opening the sides for a 84mm or 85 mm piston bore? But what about the valves if I have that 84mm or 85mm bore what sizes valves would I need for this setup oversize or the usual?</TD></TR></TABLE>
Makes no difference, you can run stock or half mm over.
Do you guys have cores too.. i need another head for back up engine build up..gettin block done...if so how much is b16head.core.then how much for it all together....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOstedEM1 »</TD></TR><TR><TD CLASS="quote">Do you guys have cores too.. i need another head for back up engine build up..gettin block done...if so how much is b16head.core.then how much for it all together....</TD></TR></TABLE>
I have the same question do you guys have cores? Secondly is there any charge to open up to 84mm bore?
I'm getting a b16 head soon, and i was wondering, since i just baught toda valvesprings, if i just send them with the head, if you guys could just put those in instead of the Supertech ones?
