Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
PortFlow heads with SuperTech valve trains
Old Jun 1, 2005 | 02:50 PM
earl's Avatar
Default PortFlow heads with SuperTech valve trains
Available for the B series, D series, H series, K series and S2000 blocks.
Head is disassembled, hot tanked, ported and polished by PortFlow, competition 3 angle valve job, surfaced and reassembled with SuperTech stainless steel nitride coated valves (choice of stock size or .5mm oversized), ST titanium retainers and ST dual valve springs. Price is $1600 with free return shipping.
IM Ninesecrx for any questions...
Check our budget head pricing here:
http://www.laskeyracing.com/shop/portflow.htm
Here are some pix:
Modified by earl at 8:18 PM 5/1/2007
Old Jun 22, 2005 | 10:08 PM
Micha's Avatar
FAILWGN
Default Re: PortFlow heads with SuperTech valve trains (earl)
Do you do spotfacing for larger bore then stock? Say going from 81mm to 84.5mm for B18B? Thanks? Pm me with prices please.
Old Jun 23, 2005 | 12:02 PM
ninesecrx's Avatar
Default Re: PortFlow heads with SuperTech valve trains (Blu99teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg &raquo;</TD></TR><TR><TD CLASS="quote">Do you do spotfacing for larger bore then stock? Say going from 81mm to 84.5mm for B18B? Thanks? Pm me with prices please.</TD></TR></TABLE>
Portflow does not spotface.
Old Jun 24, 2005 | 09:32 AM
Micha's Avatar
FAILWGN
Default Re: PortFlow heads with SuperTech valve trains (ninesecrx)
Thanks.
Old Jul 6, 2005 | 05:45 PM
ninesecrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg &raquo;</TD></TR><TR><TD CLASS="quote">Thanks. </TD></TR></TABLE>
Welcome
Old Jul 10, 2005 | 07:45 AM
g2_teg_'s Avatar
what are the advantages of ST titanium retainers and ST dual valve springs?
Old Jul 11, 2005 | 06:22 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx &raquo;</TD></TR><TR><TD CLASS="quote">
Portflow does not spotface.</TD></TR></TABLE>
My portflow head had the bowls machined to match the cylinder bore (84.5mm), as well as CC'd to ensure that each bowl is identical in volume.
Old Jul 11, 2005 | 07:59 AM
ninesecrx's Avatar
Default Re: PortFlow heads with SuperTech valve trains (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">
My portflow head had the bowls machined to match the cylinder bore (84.5mm), as well as CC'd to ensure that each bowl is identical in volume. </TD></TR></TABLE>
Yes, he can open them up on the sides for whatever size bore you want, but spot faceing is done with a boreing bar all the way around...even where the valves sit which they dont do.
Old Jul 22, 2005 | 12:50 PM
FairlightRacing's Avatar
How long is the turn around time?
Old Jul 27, 2005 | 07:06 AM
Project SSAP1's Avatar
Default Re: PortFlow heads with SuperTech valve trains (FairlightRacing)
would those ST valve springs & TI retainers be acceptable for using toda spec b or c cams in the F20C(S2000) head??? and what is the turn around time??
Old Aug 2, 2005 | 03:28 PM
earl's Avatar
Default Re: PortFlow heads with SuperTech valve trains (Project SSAP1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project SSAP1 &raquo;</TD></TR><TR><TD CLASS="quote">would those ST valve springs & TI retainers be acceptable for using toda spec b or c cams in the F20C(S2000) head??? and what is the turn around time??</TD></TR></TABLE>Absolutely on the SuperTech. I think it is the best components available for the S2000. Turn around time is 1-2 weeks.
Old Aug 11, 2005 | 07:28 PM
whatVTEC's Avatar
bump for earl
Old Aug 15, 2005 | 08:46 AM
clint g's Avatar
Default Re: PortFlow heads with SuperTech valve trains (whatVTEC)
how long are yall running this promotion? I gotta get my money up
Old Aug 15, 2005 | 12:38 PM
ninesecrx's Avatar
Default Re: PortFlow heads with SuperTech valve trains (clint g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clint g &raquo;</TD></TR><TR><TD CLASS="quote">how long are yall running this promotion? I gotta get my money up</TD></TR></TABLE>
Hurry Hurry Hurry... It will still be ready when you are
Old Aug 16, 2005 | 06:25 AM
clint g's Avatar
So there's no extra charge for opening the sides for a 84mm or 85 mm piston bore? But what about the valves if I have that 84mm or 85mm bore what sizes valves would I need for this setup oversize or the usual?
Old Aug 16, 2005 | 04:12 PM
ninesecrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clint g &raquo;</TD></TR><TR><TD CLASS="quote">So there's no extra charge for opening the sides for a 84mm or 85 mm piston bore? But what about the valves if I have that 84mm or 85mm bore what sizes valves would I need for this setup oversize or the usual?</TD></TR></TABLE>
Makes no difference, you can run stock or half mm over.
Old Aug 16, 2005 | 07:35 PM
1998 hatch dx's Avatar
just curious what kind of gains i'll see from this on stock b16 w/ skunk2 cams etc?
Old Aug 17, 2005 | 12:06 AM
BoOstedEM1's Avatar
Do you guys have cores too.. i need another head for back up engine build up..gettin block done...if so how much is b16head.core.then how much for it all together....
Old Aug 17, 2005 | 07:41 AM
sean's Avatar
Default Re: PortFlow heads with SuperTech valve trains (BoOstedEM1)
awesome deal. now i just need to find a vtec head.
Old Aug 17, 2005 | 01:14 PM
racecarpete's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOstedEM1 &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys have cores too.. i need another head for back up engine build up..gettin block done...if so how much is b16head.core.then how much for it all together....</TD></TR></TABLE>
I have the same question do you guys have cores? Secondly is there any charge to open up to 84mm bore?
Old Aug 19, 2005 | 10:18 AM
ninesecrx's Avatar
Default Re: PortFlow heads with SuperTech valve trains (SilverCivic2k)
We have 2 gsr cycl. head cores ready to go. Cores are $500 and of course would be in perfect condition.
Old Aug 24, 2005 | 09:36 AM
clint g's Avatar
bump
Old Sep 2, 2005 | 07:56 AM
guymosiris's Avatar
Got my head back last night, less than 2 weeks. Thanks Earl
Old Sep 2, 2005 | 12:04 PM
ek9800's Avatar
I'm getting a b16 head soon, and i was wondering, since i just baught toda valvesprings, if i just send them with the head, if you guys could just put those in instead of the Supertech ones?
Old Sep 3, 2005 | 05:30 PM
earl's Avatar
Default Re: PortFlow heads with SuperTech valve trains (ek9800)
Yeah, we can do that and it will be cheaper, of course.
