Need help car just dies when rev'ed
Old Jun 1, 2005 | 02:05 PM
DOHClessEF-9's Avatar
Default Need help car just dies when rev'ed
i got a 91 crx obd1 with a dx block si head combination and im running a z6 manifold, car idles really low like 500rpm and when i rev it the car just bogs and dies any help or feedback is helpful thanx
Old Jun 1, 2005 | 02:22 PM
CRseXy's Avatar
Default Re: Need help car just dies when rev'ed (DOHClessEF8)
what ECU are you using???
Old Jun 1, 2005 | 07:39 PM
Default Re: Need help car just dies when rev'ed (pogiTSI)
i was using a p06, but now im running a p75 because i thought it was the ecu so any help????
Old Jun 27, 2005 | 11:57 AM
sik_one's Avatar
bump
I've searched everywhere, but with no luck so far. My car does the same thing. I recently dropped in a B18c1 into my EK and am currently running on an unchipped P28. My car sometimes idle super low and sometimes die. It's getting annoying. Any clue as to what's causing this? Thanks!
Old Jun 27, 2005 | 12:35 PM
91sihatch's Avatar
Get the right ECU. The P75 is an LS ecu and is causing your car to run too rich.
sik_one.. chip that p28 you are running lean. Do not drive it with an unchipped p28.
Old Jun 27, 2005 | 01:32 PM
sik_one's Avatar
Thanks yo. I have access to an OBDII P72 so I'll use that for now.
Old Jun 27, 2005 | 02:21 PM
bengay's Avatar
that happend when my distrubutor went out!!!!!! bump
Old Jun 27, 2005 | 03:24 PM
sik_one's Avatar
almost all my ignition parts are brand new. plus, the car fires right up after dying on low idle. it doesn't do it, not yet at least, with the P72.
Old Sep 16, 2008 | 05:57 AM
crick_james's Avatar
Default Re: (sik_one)
did the ecu fix the problem ? i know its an old topic but my friend is having this problem
Royal_C!ty
May 31, 2012 01:31 PM
$LiLPooky$
Engine Management and Tuning
Nov 19, 2009 04:01 AM
Out of every "game"
Mar 9, 2006 08:34 AM
MeanGreenEG9
Dec 3, 2002 06:34 AM
