will civic be ok on 18s 205/35
Old Jun 1, 2005 | 01:46 PM
civic1284's Avatar
Default will civic be ok on 18s 205/35
hello, i got a honda civic dx, not lowered at all, but i was wondering whether 18 x 7.5 alloys would fit without any rubbing etc
Old Jun 1, 2005 | 01:50 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: will civic be ok on 18s 205/35 (civic1284)
it depends on the tire size...i'm not sure how wide of a rim you can go, but, the 18" will be fine. The car will be incredibly slow with 18's unless you're making at least 200whp
blackwidow45456's Avatar
that's pretty big for a civic.
Old Jun 1, 2005 | 01:51 PM
LoganMantits's Avatar
Default Re: (blackwidow45456)
why?
haveaniceday's Avatar
i think theyll be alright.. if you lower it might be a diff story.. but i dont have em .. and i never had... those are kinda big for my liking.. im sure someone can give u a good answer
Old Jun 1, 2005 | 01:52 PM
IT'S ME DAVID's Avatar
NooB
i think if ya putting oon 18" the width might be the problem because i think 7.5" might be to wide for 18". i had 19" 7.5" width on my 99 accord with 35 series tires and it was rubbing.
Old Jun 1, 2005 | 02:18 PM
2000psi's Avatar
Default Re: will civic be ok on 18s 205/35 (b20vtecallmota)
I wasn't asking why because it's his car. I personally would NEVER go over 15" on a civic, unless you are making over 300whp, then I might go 16" for traction.
Old Jun 1, 2005 | 02:19 PM
1_Slo_zc's Avatar
I had some 18x7's on one of my old civics and they fit fine with 35's
93_civic_hatch's Avatar
Default Re: will civic be ok on 18s 205/35 (1_Slo_zc)
Old Jun 1, 2005 | 02:29 PM
del sol1658's Avatar
all show and no go? Dont go over 17s. Trust me
Old Jun 1, 2005 | 03:13 PM
RunningWithCows's Avatar
New User
with you baller 18's why dont you get ride of those and get some 16's and lower your car with the rest of it it would look alot better then a stock civic on 18's
Old Jun 1, 2005 | 03:34 PM
5poonhatch's Avatar
16" SPOONS YEA BABY!!!!!!!!!!!!!!!!!!
Old Jun 1, 2005 | 03:44 PM
mrlegoman's Avatar
Default Re: (5poonhatch)
You could fit 18" but then you'll never be able to lower the car without rubbing. Without lowering it, the 18" are just gonna look, well, jacked up. If your going for the bling, get some lowering springs and stick with the 16's. jmo
Old Jun 1, 2005 | 03:50 PM
typeoneeg6's Avatar
Default Re: (mrlegoman)
you're gonna do nothing but bend wheels with 35 series tire. itll ride like *****. and the taller the o.d. the more effects youre gearing. taller tire = slower acceleration. just get some 15's maybe 16's.
Old Jun 1, 2005 | 06:25 PM
nota-eg's Avatar
Default Re: (typeoneeg6)
I have 18's w/ a 1.5" drop. Only time I get tire rub is if I turn the wheel completely to the left or right.
Not sure if they're 7" or 7.5". They're going in the trash this summer once I can afford a set of 16" enkei's.
Old Jun 1, 2005 | 07:09 PM
If you wanna go big, the biggest should be like 17s anything over that isn't gonna do much but look goofy and make the car slower. I got 17s and they never rub or anything with plenty of room for a drop.
Old Jun 1, 2005 | 07:10 PM
NotSoSimple's Avatar
Default Re: (notabassist31)
^^What he said. My DX came with Konig Monsoons in the 18" flavor. They look decent, and I get compliments, but they ride like a Ford, and they rub on full crank.
So yes, you can put them on, but you probobly will have some problems rubbing.
Old Jun 1, 2005 | 07:22 PM
KtHaNxBai's Avatar
Default Re: will civic be ok on 18s 205/35 (haveaniceday)
NO!
digi198816
Apr 2, 2010 06:53 PM
2.3lcivic
Apr 9, 2008 07:28 AM
hondapwr
Aug 25, 2004 08:12 AM
lDanny
Mar 18, 2004 07:18 PM
AznInvasion
Aug 29, 2001 12:41 PM
