Ticking noise
Old Jun 1, 2005 | 01:44 PM
mdiym13's Avatar
Default Ticking noise
When ever I drive my car I hear a ticking noise that increses in loudness the higher the rpms. It usually sounds really loud when I first turn on the car. Its a first gen b16a. can any one help??
Old Jun 1, 2005 | 02:21 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Ticking noise (mdiym13)
Valve adjustment, or bad lma
Old Jun 1, 2005 | 04:48 PM
mdiym13's Avatar
what is a lma??
Old Jun 1, 2005 | 05:19 PM
Combustion Contraption's Avatar
Default Re: (mdiym13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mdiym13 &raquo;</TD></TR><TR><TD CLASS="quote">what is a lma??</TD></TR></TABLE>
Lost Motion Assembly. Its part of your valvetrain.
Old Jun 1, 2005 | 05:30 PM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mdiym13 &raquo;</TD></TR><TR><TD CLASS="quote">what is a lma??</TD></TR></TABLE>lost motion assembly....it's part of your valvetrain. Honda incorporates these little shock absorbers to keep the vtec rockers in check when they are not being used...when they go bad they don't cushion the rockers and the rockers tap themselves to death on everything
Modified by builthatch at 9:49 PM 6/1/2005
Old Jun 2, 2005 | 12:19 AM
JSJ EG6's Avatar
Default Re: (builthatch)
what will happen to your motor if you keep on driving with bad LMA?
Old Jun 2, 2005 | 04:28 PM
Premature cam wear and ticking noises.
Old Jun 3, 2005 | 10:24 AM
onepoint6i's Avatar
Default Re: (LsVtec92Hatch)
also check your oil..
hopefully its not a spun bearing
Old Jun 3, 2005 | 10:28 AM
Default Re: (1.6i)
Cars will seize with spun bearings 99% of the time. If it is a bearing you are hearing, its not spun yet, but could be on its way. Sometimes you can 'feel' a mis-aligned bearing through the clutch pedal. Sometimes.
Old Jun 3, 2005 | 10:31 AM
onepoint6i's Avatar
oh..yeah i meant crushed bearing good info^^^
Agent Zero
Honda S2000
19
Jul 5, 2007 11:51 AM
gsr-2nr
Honda Motorcycles
11
Apr 6, 2006 12:21 PM
dc28012
Apr 22, 2004 01:00 PM
KRiS1
Sep 2, 2003 04:09 PM
bwan24
May 25, 2003 01:07 PM
