help/advice/feedback for srs light
Old Jun 1, 2005 | 12:44 PM
94ls's Avatar
Default help/advice/feedback for srs light
Hey all, well ive done a search and found nothing to be very useful. my fiance's 01 V6 coupe has a SRS light on.
as of about 2 weeks ago, her side airbag light indicator kept flashing on and off periodically. I realize that tends to happen when something is placed in the seat or if someone is leaning to the side while riding in the seat. The light will come on and then go off. The light never stays on constantly. This will even happen when nothing is on the seat or no one is sitting in the seat.
Since the light doesn't stay on and I didn't want to take the car to my local dealership and get charged out the ***.... i simply unscrewed the bulb from behind the guages so it can't flash anymore.
However, when i disconnected everything to get the bulb out, replaced the connectors and re installed the guages... the main SRS light is now ON and stays ON. I thought to remove that bulb, but there's no bulb to remove????? anyway, long story short, what can i do at this point to avoid taking it in. I can't see why something would be wrong with the SRS just by removing the side airbag bulb. any help and feedback would be great, thanks
Old Jun 1, 2005 | 12:56 PM
hypnosisracing's Avatar
Default Re: help/advice/feedback for srs light (94ls)
Well...for one, that SRS light comes on to let you know that the airbag has been deactivated because of a unusual weight strain put on the sensor...its completely normal and is not a "problem", it just means something is sitting on the sensor and that the side air bag isnt going to go off while that person, thing...whatever is on the sensor is in the same position...its a safety feature.
You'll notice if you sit too far to the door side of the seat, the light should come on, if you set something heavy (books, box, etc) on that side of the seat or the weight shifts while driving to that side, it will also come on. Its supposed to.
As far as your problem now, i dont know what to tell you, but that light is supposed to come on when an unusual weight is put on the sensor...just letting you know about it.
Old Jun 2, 2005 | 08:03 AM
Pairallel's Avatar
2 possibilities:
1. Low Battery Charge Can Cause SRS DTCs
On all Honda models with SRS, a battery that’s not fully charged can cause an SRS DTC; and this can be any DTC from 5-1 through 8-6. In Honda service manuals, these DTCs are listed as an “Internal failure of SRS unit,” but low battery voltage can also cause them to set. So, before you troubleshoot the SRS for any of these DTCs, follow these guidelines:
1. Check the state of charge and the condition of the battery. Recharge or replace the battery as needed.
2. Check the charging system, and make any needed repairs.
3. Use the PGM Tester to clear any SRS DTCs, then turn the ignition switch ON (II), and check the SRS indicator:
• If the SRS indicator stays on longer than 6 seconds, check for DTCs with the PGM Tester. If the DTCs are set again, replace the SRS control unit.
• If the SRS indicator comes on and then goes off 6 seconds later, the system is OK.
4. Start the engine with the headlights, brake lights, and A/C on to load the system. If the SRS indicator stays off, the DTC was caused by a battery or charging system problem that’s now fixed. Return the vehicle to your customer.
2. TSB #02-034 - see next post
Old Jun 2, 2005 | 08:06 AM
Pairallel's Avatar
TSB #02-034 SRS Indicator Comes On With SRS DTC(s) 15-1, 15-2, 15-3SYMPTOM
The SRS indicator is on, and one or more of these SRS DTCs are set:
• SRS DTC 15-1 (faulty OPDS unit or OPDS not initialized)
• SRS DTC 15-2 (faulty side airbag indicator light circuit)
• SRS DTC 15-3 (faulty OPDS sensor)
PROBABLE CAUSE
DTC 15-1
A faulty occupant position detection system (OPDS) unit.
DTC 15-2
• A faulty OPDS unit
• Side airbag cutoff indicator (SIDE AIRBAG; SIDE AIRBAG OFF in later models) is faulty.
• Fuses in certain circuits (such as the odometer) blow or are removed while the ignition switch is turned to ON (II)
• Any part of the SRS circuit (particularly the gauge assembly) is disconnected while the ignition switch is turned to ON (II)
DTC 15-3
• OPDS sensor interference from an electrical appliance operating near the front passenger seatback
VEHICLES AFFECTED
Accord 2-door:
2000–01 - ALL
2002: From VIN 1HGCG3...2A000001 thru 1HGCG3...2A019751
From VIN 1HGCG2...2A000001 thru 1HGCG2...2A025350
4-door:
2000–01 - ALL
2002: From VIN 1HGCG5...2A000001 thru 1HGCG5...2A111392
From VIN 1HGCG6...2A000001 thru 1HGCG6...2A109960
From VIN 1HGCF8...2A000001 thru 1HGCF8...2A111324
From VIN 1HGCG1...2A000001 thru 1HGCG1...2A107577
From VIN JHMCG5...2C000001 thru JHMCG5...2C031604
From VIN JHMCG6...2C000001 thru JHMCG6...2C025782
From VIN JHMCF8...2C000001 thru JHMCF8...2C000492
CORRECTIVE ACTION
Repair the vehicle as indicated by the DIAGNOSIS.
Old Jun 27, 2005 | 06:44 AM
carquest's Avatar
Default Re: help/advice/feedback for srs light (Pairallel)
The SRS light has been on in my 2000 Accord EX for a few years. I don't recall the mileage - under 50k. I took the car to the dealer when it first went on and was told that I needed a new battery. They replaced the battery and the light went out. Within a few days the light was back on. I asked a nearby dealer about it and they said it would cost a lot of money just to diagnose the problem. I was reading the posts here and got the impression that there is a separate indicator for the passenger airbag. Could someone explain? I also replaced the headlight lamp three times in a short period of time and had some water in my trunk. Is there a connection? I would like to sell this car. Any advice?
Old Jun 27, 2005 | 08:20 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94ls &raquo;</TD></TR><TR><TD CLASS="quote">my fiance's 01 V6 coupe has a SRS light on.
What trouble code does it have stored?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94ls &raquo;</TD></TR><TR><TD CLASS="quote">I can't see why something would be wrong with the SRS just by removing the side airbag bulb. </TD></TR></TABLE>
The SRS control unit monitors the bulb circuit, a missing bulb would make it fail and set a trouble code.
yobbr5
Honda Civic (2006 - 2015)
Nov 26, 2007 06:41 PM
intezn
May 20, 2003 07:47 PM
AccordCoupe
May 9, 2003 10:00 AM
