car wont crank, oil light on.
i just got done with everything and im tring to get my car to crank its a d16y7 motor and i havent gotten it to run yet. now when i turn the key after the check engine light turns off the oil light comes on and the battery light stays on unless hooked up to a charger.
the car has been sitting out for a while... but it has new oil its a new headgasket, and stuff but other than that pretty much just stock.
the car rotates and half the time sounds like its trying to crank but doesnt. one time it started and cut off with in seconds.
is there any one who has an idea on what i should try first. ive checked the oil its at the right level.
new battery still wont crank... i really doubted the battery thing because its not turning over slow its turning over regular like its trying to crank but wont. also its getting spark
Guest
Posts: n/a
The car will still start even if there's like 4 drops of oil in it. It will just be damaged severly within a few seconds. Double check the distributor cap for moisture and whatnot. It sounds like it is turning over fine. Are you sure that the timing is correct after you changed the head gasket? Do you know anyone that can do a leakdown test for you?
im positive the timings correct but moisture i havent checked for as for a leakdown test na i dont know anyone immediately that can do one for me but ill look in to it. im thinking the distributor might be bad because it came off my friends car
