ZC block and head
Old Jun 1, 2005 | 12:10 PM
illcrx's Avatar
Default ZC block and head
I was wondering if the block from the sohc zc and the head from the dohc zc were compatable?
Old Jun 1, 2005 | 12:13 PM
Tyson's Avatar
Default Re: ZC block and head (illcrx)
the block of the SOHC ZC is the same as D16A6.
im not sure if A6 block matches with a DOHC ZC head, but i figure someone else can tell you that.
Old Jun 1, 2005 | 12:19 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: ZC block and head (Tyson)
not compatible
Old Jun 1, 2005 | 01:56 PM
90SICRX's Avatar
The DOHC head will not bolt up to any SOHC blocks the bolt pattern on the head is different.
Old Jun 1, 2005 | 08:19 PM
cbrodac0424's Avatar
Default Re: (90SICRX)
hey i would like to inform you that they do line up or on my part that it was a lucky shot but they should line up and i think it will work also on the d15b vtec so good luck.
Old Jun 1, 2005 | 08:35 PM
Mach69's Avatar
Default Re: (cbrodac0424)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbrodac0424 &raquo;</TD></TR><TR><TD CLASS="quote">hey i would like to inform you that they do line up or on my part that it was a lucky shot but they should line up and i think it will work also on the d15b vtec so good luck.</TD></TR></TABLE>
Then you must have had a DOHC ZC block, because I keep reading on here that the DOHC ZC head will not fit on any other D-series block besides the DOHC ZC block.
I do remember reading about someone putting a DOHC ZC head on a SOHC block, but it took a lot of work and isn't worth it, and I highly doubt I'll be able to find that thread.
sedrohatchstyle
Oct 30, 2008 06:34 AM
Tyounin608
Dec 21, 2006 08:37 AM
Crxsamurai
Aug 24, 2006 04:46 PM
Civichatch27
19
Dec 8, 2004 08:13 PM
johnpowellcrx
Oct 26, 2004 10:58 AM
