rad fluid overflowing
Old Jun 1, 2005 | 11:52 AM
blaak-crx's Avatar
Default rad fluid overflowing
Got an Ls-Vtec set-up in my 1991Crx. Everytime I go on the race track, the rad fluid overflows the container causing the car to wipe-up! I just changed the head gasket and other parts to fix my overheating problem. Note that this overflowing problem started since day one. Still using my stock rad.
Is it a radiator problem? Need a bigger one?
Old Jun 1, 2005 | 12:01 PM
Outsane's Avatar
Default Re: rad fluid overflowing (blaak-crx)
sounds like you still have head gasket leak..
Old Jun 1, 2005 | 12:02 PM
CRseXy's Avatar
Default Re: rad fluid overflowing (Outsane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you still have head gasket leak..</TD></TR></TABLE>
agree, Its pushing that fluid out.
Old Jun 1, 2005 | 02:05 PM
Steemo's Avatar
Default Re: rad fluid overflowing (pogiTSI)
did you have the head resurfaced when you replaced the headgasket. Your head may be warped or the block may be out of spec too. Hopefully you didnt do all that work and not go through the correct procedures.
Old Jun 1, 2005 | 02:32 PM
PURPLETERROR aka BIGMATT's Avatar
warped head, or block, remove and have it checked w a straight edge
Old Jun 1, 2005 | 02:42 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Radiator cap could be bad..
Replace or have it tested..
SupaSedan
Nov 6, 2007 12:47 AM
moosta936
Mar 4, 2007 04:14 PM
gtowni3
Dec 31, 2005 11:56 AM
eg crunkmonster
Feb 6, 2005 06:23 PM
92silude
Dec 8, 2004 09:33 AM
