Replacing cracked head: questions..
Old Jun 1, 2005 | 09:44 AM
mstewar's Avatar
Default Replacing cracked head: questions..
this is on neither of my ITRs, so no one get worried..
when replacing the head(current one) with another used head(of fairly high mileage), is it necessary to have the head magnafluxed and rebuild it, or can I just plop it on as is?
I assume if I had to do this I need to pull the valvetrain and then take it to a machine shop of some reputable nature for this..
Old Jun 1, 2005 | 09:49 AM
Dave_B's Avatar
I would have it checked for cracks or warping but that would be about it for me provided it worked fine before it was removed
Old Jun 1, 2005 | 10:01 AM
Kendall's Avatar
At the very least have it pressure tested and resurfaced.
Old Jun 1, 2005 | 10:03 AM
Jon D's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">At the very least have it pressure tested and resurfaced.</TD></TR></TABLE>
resurfaced will bump your compression too
Old Jun 1, 2005 | 10:24 AM
98TypeSH's Avatar
Default Re: (Jon D)
pressure tested, resurfaced, new seals all for about 139 bucks.
Old Jun 1, 2005 | 10:39 AM
mstewar's Avatar
Default Re: (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">pressure tested, resurfaced, new seals all for about 139 bucks.</TD></TR></TABLE>
got it..
this will be going on the existing block.. should I pull the block and do this as well or will I be ok just getting the head redone?
Old Jun 1, 2005 | 05:32 PM
ildknyli's Avatar
Default Re: (mstewar)
How do you pressure test a head?
ITR092
Feb 10, 2006 05:27 PM
RacingLude
Jun 2, 2005 12:11 PM
B18Redline
Mar 26, 2005 10:00 PM
erebunicrx
14
Mar 11, 2005 11:45 AM
JDMlyfestyle
10
Nov 14, 2004 05:42 AM
