Car wont start......
Old Jun 1, 2005 | 08:43 AM
MrPotatoeHead's Avatar
Default Car wont start......
Ok last night, I was on the way home and I stoped at a stop light. Light turned green and I started to go and right after I shifted into second my car stalled and stopped running. Pushed it over to the side of the road. Tried to start it and it just cranked. Got it towed home and tried to rule out the problem. Fuel pump kicks on, I have spark,changed the plugs and wires, put gas into the intake manni,and checked the timming. It seems its not getting any fuel.. Not sure what it is.Please help. Thanks in advance..
--Nick--
Old Jun 1, 2005 | 08:48 AM
Default Re: Car wont start...... (MrPotatoeHead)
Oh and its a 92 cx hatch...
Old Jun 1, 2005 | 09:12 AM
I NEED HELP NOW>>>>>.
Old Jun 1, 2005 | 09:31 AM
Santys EK's Avatar
go to a mechanic
thats how its going to get fixed best
scott
Old Jun 1, 2005 | 09:43 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Car wont start...... (Santys EG)
lol get a mechanic? That defeats the purpose of being on this board! lol
So you think your not getting fuel... did you check all the fuses? Grounds? It sounds like you have a bad ignitor box in the distributor, but you said you have spark so thats rules that out....
Old Jun 1, 2005 | 09:49 AM
civictildeath's Avatar
Default Re: Car wont start...... (JDM_Ej)
pull your injectors out and get a dry rag and sit them on it and crank car for a sec to see if any fuel comes out of them.
Old Jun 1, 2005 | 10:41 AM
j0nptw's Avatar
Default Re: Car wont start...... (civictildeath)
the same thing happened to me except i'm not gettin any spark, but i'm currently swapping out my d16z6 and i'm replacing the timing belt on it and i wanna check the timing belt before i check the ignition coil, but i wanna see what's wrong with yours too
Old Jun 1, 2005 | 10:52 AM
Tomdata's Avatar
Does the car try to run when you put fuel in the intake manifold?? Starting fluid is better to test this than fuel.. Get something with ether in it. If it does run on ether then I would say its time to check for fuel pressure. That is if you are sure the pump is turning on. If you don't have the tools to check for fuel pressure I agree with civictildeath that you should pull the fuel rail ( with the injectors in it) and see if you get fuel when you crank the engine. Its probably a bad pump or filter if it will run on ether. Good luck dude!!
Old Jun 1, 2005 | 10:55 AM
AllMotorLSi's Avatar
this is another good reason to swap!
Old Jun 1, 2005 | 11:07 AM
Default Re: (AllMotorLSi)
ok i went and checked if i was getting fuel into the cylinders. and the plugs get wet. and i also put in z6 injectors and still nothing...so i was turning the motor over with a 17mm wrench and when its suppose to compress it make a wistle noise and its not hard to push...what you think.. could you blow a head gasket if it doesnt overheat?
Old Jun 1, 2005 | 12:02 PM
Default Re: (MrPotatoeHead)
anyone....
Old Jun 1, 2005 | 01:04 PM
up...
Old Jun 1, 2005 | 01:07 PM
d16y8ej8's Avatar
check the compression on all four cylinders just to be sure that you have none
Old Jun 1, 2005 | 01:09 PM
d16y8ej8's Avatar
next you need to locate the compression leak. theres multiple ways to check this, long and drawn out. make sure all the spark plugs are tight before you do anything. if there not torqued correctly the aluminum head will expand and contract enough to back the plugs out
Old Jun 1, 2005 | 01:11 PM
DualAudio's Avatar
umm... there is another park that controlls the fuel intake i forgot what its called but you should see it in your manuel its a really small part that is hella spendy
Old Jun 1, 2005 | 01:13 PM
d16y8ej8's Avatar
check fuel filter
Old Jun 1, 2005 | 02:07 PM
Default Re: (d16y8ej8)
WHAT.....Speak ******* english please...
Old Jun 1, 2005 | 03:01 PM
RunningWithCows's Avatar
New User
time to make your hatch go faster go get a gsr or ls vtec that make problem go away
Old Jun 1, 2005 | 03:07 PM
Default Re: Car wont start...... (RunningWithCows)
you want to buy it for me????
Old Jun 1, 2005 | 03:46 PM
Mike Ockhurts's Avatar
i had the saem problem, i changed my ecu it it worked like a charm
Old Jun 1, 2005 | 04:53 PM
Default Re: Car wont start...... (cx Son)
anyone in or close to woodstock ill that can let me use a ecu?
Old Jun 1, 2005 | 09:06 PM
Hurricane's Avatar
If the ECU were bad enough to cause a completely dead engine, you wouldnt be getting any fuel through the injectors and probably no spark either.
Is it possible your timing belt broke, as this will make you think the engine just stalled but it wont run n matter what.
If you did break the T belt then your valves are bent.
Take off the top timing belt cover and then turn the engine.
Old Jun 1, 2005 | 10:09 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: Car wont start...... (Hurricane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hurricane &raquo;</TD></TR><TR><TD CLASS="quote">
If you did break the T belt then your valves are bent.</TD></TR></TABLE>
Not always true.
Old Jun 1, 2005 | 11:45 PM
egryda's Avatar
Default Re: Car wont start...... (INVALID)
have you checked your ignition coil?
Old Jun 2, 2005 | 01:06 AM
Hurricane's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INVALID &raquo;</TD></TR><TR><TD CLASS="quote">Not always true. </TD></TR></TABLE>
According to the Honda Engineers who built the engine, YES it is always true.
