gas tank Venting??? on Crx b16 swap.
Old Jun 1, 2005 | 08:37 AM
88crxhfb16's Avatar
Default gas tank Venting??? on Crx b16 swap.
I don't think my gas tank is venting properly since my engine swap. when I get gas and remove the cap there is always a lot of air pressure that releases. is this normal? if not, will it hurt to leave it as is?
Old Jun 1, 2005 | 08:56 AM
Outsane's Avatar
Default Re: gas tank Venting??? on Crx b16 swap. (88crxhfb16)
did you change any of the fuel lines on the firewall?
Old Jun 1, 2005 | 09:21 AM
EP3_05's Avatar
When I remove my cap it releases pressure. It has done this for three years and I have had zero problems with my swap. When I fill up my 99 G20 it also releases pressure. I am pretty sure it is normal but it depends on what you mean by alot of pressure.
Old Jun 1, 2005 | 09:38 AM
crx-treme's Avatar
Default Re: gas tank Venting??? on Crx b16 swap. (91civic)
yup mine releases pressure too
now that i think about it, both of my rexes do that
Old Jun 1, 2005 | 09:46 AM
Joebroni's Avatar
It SHOULD do that, it's not a bad thing.
Old Jun 1, 2005 | 10:30 AM
99teggsr's Avatar
Default Re: (Joebroni)
Was your gas tank vapor line blocked off ? its right where the main fuel line comes in from the firewall. I think it goes the the charcoal tank, as long as that is vented into the air or the charcoal tank then you should be fine. If it was blocked off, it might be a little dangerous.
Old Jun 1, 2005 | 02:19 PM
88crxhfb16's Avatar
Default Re: (99teggsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99teggsr &raquo;</TD></TR><TR><TD CLASS="quote">Was your gas tank vapor line blocked off ? its right where the main fuel line comes in from the firewall. I think it goes the the charcoal tank, as long as that is vented into the air or the charcoal tank then you should be fine. If it was blocked off, it might be a little dangerous. </TD></TR></TABLE>
I'll check, i noticed some of the vacuum lines have been capped off since the swap also. wonder if this could be related?
Old Jun 1, 2005 | 02:21 PM
88crxhfb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote"> but it depends on what you mean by alot of pressure.</TD></TR></TABLE>
Oh, I mean A LOT. like the cap would smack me in the eye if it got away.
Old Jun 1, 2005 | 09:15 PM
99teggsr's Avatar
Check that vent, and if its plugged it put a breather on it and you should be good to go. or hook up a charcoal canister if your crunchy granola and really mind venting gas into the atmosphere.
mariner133
Aug 8, 2018 01:01 PM
turboef90
Apr 20, 2009 07:18 PM
93_db2
Apr 12, 2008 04:11 AM
ED609
Feb 6, 2006 07:59 AM
SLOW4drINTEG
Nov 7, 2003 08:36 PM
