header wrap?
i am considering wrapping my DC header due to some slight cooling problems with my B16 on a stock radiator. is there any downside to wrapping the header?? can it damage the header or any other components?
well it does keet the heat inside, but it keeps the rest of the motor from getting as hot , and sends most of the header heat out towards the back of the car.. this would lower intake temps etc.. also keep the car from getting as hot since all the header heat isn't blasting on the radiator.. any opinions??
I think u might want to read this post first
https://honda-tech.com/zerothread?id=1136545
if you live in a dry climate wrap it. makes a huge difference. there are a lot of other things you can do to make it run cooler. lower temp thermostat, run straight distilled water with a bottle of water wetter. remove that rubber strip from the top of your firewall, buy a hood vent from carbon tricks. jegs sells carbon colored wrap if you dont want your header to look like its covered in used toilet paper after a while.
also..i thought this also helps with the scavenging effect of the header?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow91crx »</TD></TR><TR><TD CLASS="quote">ok well when people say " damage " what do they mean?? it will ruin the finish?? im not concerned with that.. define damage if some would. thanks</TD></TR></TABLE>
It traps extra heat in the header, shortening its overall life, an early cracked header. However, hot exhaust gases travel faster than "cool" exhaust gases, so your overall exhaust speed would be increased, so its a power thing, if you dont care about the money thing. I have had my teg header wrapped since 99 and although I havent had it unwrapped, I havent noticed any new noise (leaks)or any thing.
ok well if this was an ebay header i would hesitate, but from what ive seen im going to go ahead and wrap it. if the DC cracks ill just get that fancy new hytech
doubt ill encounter any problems. thanks everybody
96hatchBoy
Oct 26, 2012 09:14 AM
