Crunchy 3rd gear. Any help?
Old May 31, 2005 | 11:57 PM
siMantis's Avatar
Default Crunchy 3rd gear. Any help?
Third gear in my 91 hatch si grinds almost all the time no matter how much i mash the clutch. Any sudjestions?
Old Jun 1, 2005 | 12:02 AM
vw eater's Avatar
same here in my 90 si.....
Old Jun 1, 2005 | 12:47 AM
Malgerus's Avatar
Default Re: (vw eater)
First, try loosening off the adjustment nut. As clutches wear, they require adjustment so that they fully engage and disengage.
If it's still a problem, it could be a shot clutch or bad synchros.
Try running some GM synromesh (do a search, GuttedEF's thread is a hug FAQ about it).
Old Jun 1, 2005 | 08:58 AM
Outsane's Avatar
Default Re: (Mr. S)
Penzoil synchromesh is good stuff too..
give it 400 miles to kick in..
Old Jun 1, 2005 | 10:03 AM
vw eater's Avatar
how much is it.....?
Old Jun 1, 2005 | 10:05 AM
crx-treme's Avatar
hmm i need some too, i dont care how much it is but i couldnt find it anywhere. i looked at napa, autozone, pepboys. no luck. im sure the net has it somewhere tho......
Old Jun 1, 2005 | 11:08 AM
TAG's Avatar
TAG
Default Re: (crx-treme)
You can also use Honda MTF (get it from any Honda dealer)
I had the 3rd gear grind in my 90 CRX Si (stock tranny) and it pretty much eliminated it
Old Jun 1, 2005 | 11:56 AM
CRseXy's Avatar
Default Re: (TAG)
i know im going to get flamed up the ying yang, but double clutch it. When you press teh clutch in when your in 2nd, put it in neutrual, then let off the clutch, blip the gas a little, then press the clutch in agian, and put it in 3rd,
It alows the syncros to spin up to speed faster\closer to the 3rd gear. I do this in 2nd, I have a bad crunch in 2nd. If you do it(double clutch) you wont have to blip the gas. It makes shifting like butter.
tast2s
Nov 28, 2010 02:12 PM
gabe768
Jun 7, 2010 03:06 PM
ChrisSpade
Apr 22, 2006 10:16 PM
wickedEFguy
Mar 27, 2005 12:20 PM
B18cteg
Jul 3, 2003 10:18 AM
