obd2 EVAP???
Old May 31, 2005 | 11:07 PM
tuckin15s_8315's Avatar
Default obd2 EVAP???
anyone know anything about obd2 evap.. mine threw a code 90 and it said something about the evap canister and fuel tank... anyone know what might have cause this or how to fix it?
Old Jun 1, 2005 | 05:06 AM
JimBlake's Avatar
Default Re: obd2 EVAP??? (tuckin15s_8315)
Your gas tank, filler neck, lots of hoses, charcoal EVAP canister, some more hoses, & a whole bunch of solenoid valves work together to control evaporation from the gas tank. All that stuff has to be airtight. Code 90 says something isn't airtight. You could go to AutoZone & read the OBD-2 code (either P1456 or P1457) to narrow it down.
P1456 includes the gas tank & filler neck. You get this one if you forget to tighten the gas cap. But it also includes several hoses or even a leak in the tank itself.
P1457 includes the EVAP canister, along with a bunch of other hoses & valves.
What car is this? The details will be different depending on model & year.
Old Jun 1, 2005 | 08:37 AM
Default Re: obd2 EVAP??? (JimBlake)
yeah the car is a 99 gsr!
Old Jun 1, 2005 | 10:04 AM
JimBlake's Avatar
OK, I had to dig into that on a '98 Accord. I suppose the Integra is sorta similar, but maybe the way they split up the system might be different. There's all kinds of detail in the Helm shop manual.
https://honda-tech.com/zero...63913
Look down where I posted about that. But remember the details of which valve is supposed to be normally closed or normally open, or where each valve is physically mounted, will be different.
Old Jun 1, 2005 | 10:58 AM
HoUTX98GSR's Avatar
it could be something as simple as your gas cap isnt on tight or its leaking.. check it out first.. make sure its tight then reset tha ecu..
hondatuner020
Jun 18, 2015 11:56 PM
blacktibby07
Mar 8, 2011 08:01 AM
ek82
Aug 20, 2007 06:27 PM
b18tdelsol
Jun 11, 2002 08:43 PM
