rpm's rising while braking
Old May 31, 2005 | 07:47 PM
btotherizzle's Avatar
Default rpm's rising while braking
This just started tonight, If I'm coming to a stop with the car in neutral then the engine will rev to 1500rpm and sit there until I am stopped and off the brakes. I have checked vacuum lines and all seem ok. The car idles great while sitting just not while braking. Any ideas?
Old May 31, 2005 | 07:55 PM
speedymon's Avatar
Default Re: rpm's rising while braking (btotherizzle)
Happens to me. Don't know what it is
Old May 31, 2005 | 08:36 PM
tuan...'s Avatar
its normal, i think. when u hit ur brakes u use ur power booster which is controlled by vaccuum which comes from ur intake manifold which will take away some vaccum which will cause ur idle to go up
Old May 31, 2005 | 09:12 PM
nightrider's Avatar
regardless if you're hitting the brakes, it is normal for the type r to stay at a steady rev of 1500 or so then drop down to about 900 when it's normal. definitely noticeable when off the highway.
Old May 31, 2005 | 09:40 PM
Chris F's Avatar
Default Re: rpm's rising while braking (nightrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider &raquo;</TD></TR><TR><TD CLASS="quote"> it is normal</TD></TR></TABLE>
Yo.
Old May 31, 2005 | 10:06 PM
Ill's Avatar
Ill
Default Re: (v0gueSilver_Dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v0gueSilver_Dc2 &raquo;</TD></TR><TR><TD CLASS="quote">its normal</TD></TR></TABLE>
+2
It should drop after a short while.
Old Jun 1, 2005 | 03:12 AM
Reid's Avatar
Global Moderator
Try pumping the brake pedal when the car is idling normally. The rpm will rise.
Old Jun 1, 2005 | 03:29 AM
Ed 341's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider &raquo;</TD></TR><TR><TD CLASS="quote"> it is normal for the type r to stay at a steady rev of 1500 or so then drop down to about 900 when it's normal. definitely noticeable when off the highway. </TD></TR></TABLE>
especially if you have the A/C and/or defrost on
Old Jun 1, 2005 | 04:02 AM
So that crack I smoked last night really knocked me on my ***, because I have been driving this car for 4 years and i don't remember ever noticing that before. Thanks for the replys.
Old Jun 1, 2005 | 07:47 AM
Chris F's Avatar
Default Re: (btotherizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btotherizzle &raquo;</TD></TR><TR><TD CLASS="quote">So that crack I smoked last night really knocked me on my ***, because I have been driving this car for 4 years and i don't remember ever noticing that before. Thanks for the replys.</TD></TR></TABLE>
Is it possible you were on crack for the past 4 years, and then forgot to hit it yesterday?
Don't worry man, I always ask myself "is this sound normal?" etc... but my car is beyond help.
-Chris
Old Jun 1, 2005 | 01:25 PM
Default Re: (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
-Chris
Ya I've read some of your posts regarding your car and it's rough to have a 350 whp itr that you track, I know. Except I do it on stock brakes and without an oil cooler. I only do 10 minutes at a time in Solo 1, none of this lapping day bullshit.
drg1989
Mar 15, 2008 01:40 PM
martyball619
Aug 16, 2007 12:06 PM
JDMlyfestyle
Oct 29, 2004 12:10 PM
bOOsTiNSoHcVtEc
May 12, 2004 02:50 PM
RCautoworks
17
Oct 2, 2003 04:57 PM
