car kicks back at 3500rpm after turbo install
Old May 31, 2005 | 07:03 PM
GSRfoedoe's Avatar
Default car kicks back at 3500rpm after turbo install
ive been doin all motor for about 5 years and decided to do a turbo setup for once. its your basic drag3 setup but with a full race manifold. im runnin it off a hondata s200b and stock injectors. the car would kick back at 3500 rpm at every gear and the check engine would flash. im goin to go get it tuned with 1000cc injector next monday( i just ordered a sc 62) and i just want to make sure i dont get ran over on the freeway goin that slow.
Old May 31, 2005 | 07:09 PM
NewportSI's Avatar
Default Re: car kicks back at 3500rpm after turbo install (GSRfoedoe)
mine did that, it was in limp mode from the ecu, i believe the baro sensor code 13..
Old Jun 1, 2005 | 07:00 AM
adseguy's Avatar
running around with turbo and stock injectors
running around with turbo and stock injectors and untuned
running around with turbo and stock injectors and untuned trying to get above 3,500
Don't drive anymore and get your crap tuned before you blow somethin...the limp mode is there for a reason...TO SAVE YOUR ***
Old Jun 1, 2005 | 07:07 AM
GSRfoedoe's Avatar
Default Re: car kicks back at 3500rpm after turbo install (adseguy)
oh im not driving it around until monday.......i tried to start the car with the 1000cc injectors but the car wont idle. thanx for your input
VTteg
May 7, 2006 06:19 AM
turbod16y8
Mar 20, 2003 04:30 PM
