USDM P30 Ecu : Idle surge but no CEL
Old May 31, 2005 | 05:56 PM
amy's Avatar
amy
Default USDM P30 Ecu : Idle surge but no CEL
I just switched my ecu's in my 93 del sol with a b16 swap. I had a chipped p28 but switched to a usdm p30. the knock sensor is wired up. The idle surges even after sitting for a little while with no headlights/ac/anything on. I don't think its a vacuum leak because it never did it before, and it has absolutely no CELs... just trying to see what else someone might think it is... Thanks
Old May 31, 2005 | 06:28 PM
b18c5 EG's Avatar
my sol does the same thing and i dont think it is a vac leak either....im getting it on the road thursday and im gonna bring it to get checked out!
Old May 31, 2005 | 06:36 PM
1995Ex_Sedan's Avatar
EDIT: Nevermind, I'm retarded.
Old May 31, 2005 | 06:56 PM
Turbogixxer's Avatar
Default Re: (1995Ex_Sedan)
It happened right after you switched the ECU? Start with the IACV and fast idle.
Old May 31, 2005 | 07:06 PM
dunkd's Avatar
if we plug the chipped p28 back in everything is fine... so wouldnt that rule out the iacv and fiv?
the ecu surges like its an auto ecu, but is not. socket R17 has no resistor and it looks like it never did, the ecu looks like its never been tampered with.
The surge is a consistent 1000rpm to 1500rpm.
Something else thats a little iffy on the wiring of the car is the IAT sensor. Its just plugged in and hanging there. It has always been this way, before the p30 install so I dont think it would be causing this.
Old May 31, 2005 | 07:15 PM
Default Re: (dunkd)
I had a problem similar to this, and it was getting to me getting to me because it would work fine on a P13, but on a p28, it would surge. I traced it to a bad wire on the IACV (not saying this is your problem).
The idle surge is at any engine temp?
BTW, I have ran auto p06s on a manual with no surging.
Old May 31, 2005 | 08:56 PM
amy's Avatar
amy
Default Re: (Turbogixxer)
any other ideas?
Old May 31, 2005 | 09:22 PM
dunkd's Avatar
idle only seems to surge once the car warms up.
I unplugged the IACV plug and the surging goes away. However, for driveability issues we need the IACV hooked up.
Old Jun 1, 2005 | 07:14 AM
G3NR8's Avatar
Default Re: (dunkd)
I swapped my stock ecu and vafc for a chipped p28 running uberdata and ran into the same problem. I adjusted my idle and it helped a bit, but once I had it tuned, it went away considerably. Are you running any software? I know this isn't much of a help
Old Jun 1, 2005 | 07:23 AM
b16adx's Avatar
Default Re: (G3NR8)
My sol did the same things when i went i used a chipped p30 it would be fine but if i cut j1 and ran it un chipped it would surge but would calm down if i turned on the headlight..huh never figured it out though cuz now im running uberdata
Old Jun 1, 2005 | 07:57 AM
japspecjohn's Avatar
Default Re: (b16adx)
So strange ........ask the seller if he had any issues
Old Jun 1, 2005 | 08:46 AM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
Default Re: (japspecjohn)
Why did u swap ecu's Amy?...If I may ask
Old Jun 1, 2005 | 09:15 AM
dunkd's Avatar
switchd because usdm p30 is the RIGHT ecu for the motor, nothing beats oem ().
It did seem to react when I switch the headlights on as well, but not all the time.
I just don't understand what could be different between the p28 and the p30. Next step is to try the ecu on another obd1 5sp car and see if it does the same thing... if it does then the ecu must be bad...
The knock sensor was wired in for this ecu that wasnt used previously but I dont think a knock sensor has absolutely anything to do with idling...
Modified by dunkd at 1:58 PM 6/1/2005
Old Jun 1, 2005 | 09:55 AM
^Sammy]!.'s Avatar
Default Re: (dunkd)
Yeah mines idles a bit too not too bad its a b16a with a p05 converted to p28 chipped...im gonna clean out the IACV see if that helps.
Its funny cause when I had my EF swapped z6 with a p28 it also idled changed the IACV and FITV and still did it.
Arggggggggggh cars are a pain at times
Old Jun 1, 2005 | 10:45 AM
Tomdata's Avatar
Default Re: USDM P30 Ecu : Idle surge but no CEL (amy del sol)
Take off the intake tube and plug the bottom hole in the throttle body. If the car idles normally then it is the cold air idle bypass on the bottom of the throttle body. What I always do is just take the three 10mm bolts out that hold the cold air idle bypass on and just cut out a piece of gasket to block off both of the vacuum holes. You only need this bypass in very cold (less than 30 degrees) weather. Make sure you cut a hole in the gasket for the coolant to pass through. Then you should be good to go.
Old Jun 1, 2005 | 12:30 PM
Default Re: USDM P30 Ecu : Idle surge but no CEL (Tizom57)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tizom57 &raquo;</TD></TR><TR><TD CLASS="quote">Take off the intake tube and plug the bottom hole in the throttle body. If the car idles normally then it is the cold air idle bypass on the bottom of the throttle body. What I always do is just take the three 10mm bolts out that hold the cold air idle bypass on and just cut out a piece of gasket to block off both of the vacuum holes. You only need this bypass in very cold (less than 30 degrees) weather. Make sure you cut a hole in the gasket for the coolant to pass through. Then you should be good to go.</TD></TR></TABLE>
oh yeah i forgot you could give that a shot but Idk why it wont do it b4 with the other ecu
Old Jun 1, 2005 | 07:23 PM
dunkd's Avatar
ttt
Old Jun 1, 2005 | 07:48 PM
amy's Avatar
amy
Default Re: USDM P30 Ecu : Idle surge but no CEL (japspecjohn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspecjohn &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah i forgot you could give that a shot but Idk why it wont do it b4 with the other ecu</TD></TR></TABLE>
yea really
Old Jun 1, 2005 | 08:00 PM
b18c5 EG's Avatar
try my p30 at marcus!! if my car makes it that far....hopefully its fixed tomorrow
crxb16a90
Engine Management and Tuning
Mar 4, 2011 02:06 PM
mikeunreal2
31
Mar 12, 2006 10:28 PM
BeerBaron105
Jun 7, 2005 02:22 AM
LostSolVTEC
Jul 22, 2004 04:31 PM
