MSD igniton into b16 and/or EF wire harness, do i have to buy something?
Old May 31, 2005 | 04:57 PM
hxtasy's Avatar
Default MSD igniton into b16 and/or EF wire harness, do i have to buy something?
I know i can just tap the stock wires, since it is only two wires, but which ones? I am having trouble finding stuff on this this is all i found:
https://honda-tech.com/zerothread?id=72214
with dead links.
It is a 6Anl into a EF civic with a b16. thanks for any links/help.
Shane
Old May 31, 2005 | 06:23 PM
jdmcrx34's Avatar
Default Re: MSD igniton into b16 and/or EF wire harness, do i have to buy something? (pennhatch)
ok this is how i installed this in to my crx with a b16 and a 95 hatch with an ls.
first you have to make sure that you have every thing that you need.
msd box
msd coil
msd coil wire
its pretty simple to wire up. take out the coil and un screw the two wires on top of the coil. the red wire goes to the two black wires that are together and the white wire goes to the white/green wire. the rest should be easy to wire up if you have any other questions just ask.
es_squared
Sep 11, 2006 12:05 PM
Silver.007
Oct 12, 2005 06:50 AM
kodirtysi
Oct 6, 2005 02:45 PM
connvict
Jul 29, 2004 08:54 PM
Rod.
Jun 29, 2004 07:05 AM
