need some lugnuts...
ok wasn't sure exactly where to post this, cause it is for my civic....
i need some lugnuts to put on with my new rims....first..anyone know the thread size?
second...anyone know a decently cheap place to get some? cause someone told me that stock lug nuts wont work...
Your local tire/wheel shop would probably know. when i got new rims i asked them to put new lugs on because i wanted the colors to match. They gave me new lug nuts for about 20 dollars.
You have to get lugs with the right taper. You need lugs for aftermarket or aluminum wheels because the stock lugs for steelies will not seat properly. (Acorn style vs. straight taper I believe.) Hondas use 12x1.5 thread pitch.
they should work but they suck, personal opinion being a rim installer in a tire shop. the style like tend have dirt and such jap down in the inner hole and make it so the key wont go all the way in which causes the key to strip. more pain then helping go to tire barn or custom shop and they usually have wheel lugs for rims in stock.
