93 accord lx brake question......
Old May 31, 2005 | 02:12 PM
thelate1's Avatar
Default 93 accord lx brake question......
when my wife runs the ac in her car she said that the brake pedal is going to the floor. she said it only happens when she is at a complete stop and holding pedal so the car doesn't roll(auto). i thought maybe the extra load on the motor w/ the ac on was causing this but she said it's getting worse. things i am going to check are:
-vac leak
-brake fluid
-resevoir leaks
-brake booster
can anyone steer me in the right direction as to where to begin?
thanx
Old May 31, 2005 | 02:43 PM
deserthonda's Avatar
you need to replace your brake master cylinder get 1 from the dealer or 1 made by adler that way you dont have to mess with push rod adjustment like some of the other cheaper brands,,if you do work yourself make sure to bench bleed master before installing it
Old Jun 1, 2005 | 03:23 PM
thelate1's Avatar
Default Re: (deserthonda)
cool, but why does it only do it when a/c is on? i would think if it was the master cylinder it would be that way all the time. yes i do do work myself.
thanx for the help.
Pindanin
Jul 27, 2013 02:42 PM
Markb16a
11
Aug 26, 2010 09:12 AM
SikAuto
Jan 31, 2008 03:31 AM
thelate1
Apr 19, 2006 08:08 PM
Tenners
Sep 9, 2005 06:45 PM
