night at the local racetrack
Old May 31, 2005 | 08:57 AM
j4dlsd's Avatar
Default night at the local racetrack
So I was down at the local track and having a pretty good night, and really enjoying the R.
near the end of the night i missed a shift ( I know...I know...) the tach went up to where 12 or 13 might be. I immediately slammed on the clutch and threw the shifter into neutral. I let the car roll for a while and took a moment to listen for sounds and curse a lot. I was so dissapointed in myself!, afterwards the shifter wouldnt go into gear at all!! and i had to get the car towed to the dealer.
they ended saying my clutch is burnt out and damaged my flywheel.
I also asked them to perform a compression and leakdown and I got the following #'s
cylinder 1 (178)
clyinder 2 (178)
cylinder 3 ( 180)
cylinder 4 ( 178)
and 12% leakdown on all clyinders
now they tell me that these #'s are within spec and I have nothing to be worried about, but I'ved read alot of archive posts on how 5% leakdown is where I want to be
help??? am I in big trouble???
Old May 31, 2005 | 09:03 AM
Dave_B's Avatar
You my friend may have been one of the lucky ones.
Old May 31, 2005 | 09:47 AM
Chris F's Avatar
Default Re: (01PY0559)
1-2-3-4-5
Man that sucks
Old May 31, 2005 | 09:50 AM
Jon D's Avatar
Default Re: night at the local racetrack (j4dlsd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j4dlsd &raquo;</TD></TR><TR><TD CLASS="quote"> am I in big trouble???</TD></TR></TABLE>
no where near the trouble you could be....you lucked out bigg time, be thankful for that!
Old May 31, 2005 | 09:55 AM
BlueR's Avatar
Default Re: night at the local racetrack (Jon D)
yes, very lucky...sounds like you reacted quickly enough and the clutch took the brunt of the damage
Old May 31, 2005 | 11:47 AM
itr1244's Avatar
Default Re: night at the local racetrack (BlueR)
man. my friend just miss shifted 5th to 2nd on highway
his motor's fucked. but it was a prelude. i guess type r's motor can take more beatings
u sure u dont hear any ticking sound? there's a high chance u bent some of your valves.
Old May 31, 2005 | 12:20 PM
Kamil's Avatar
Default Re: (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">1-2-3-4-5
Man that sucks </TD></TR></TABLE>
I think this is an advertisment for a BMW short shifter
Old May 31, 2005 | 12:22 PM
Chris F's Avatar
Default Re: (Kamil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamil &raquo;</TD></TR><TR><TD CLASS="quote">I think this is an advertisment for a BMW short shifter </TD></TR></TABLE>
I couldn't find an animation for a honda, and gave up. Lots of money shift posts in this forum.
Old May 31, 2005 | 03:39 PM
j4dlsd's Avatar
phew!!! thanks for the feedback guys!
I asked my trusted honda machanic, and called several other acura dealerships in my area and they say that my #'s are fine, high compression Hondas usually put out 175-200 on normal working cylinders and the 12% leakdown I got is nothing to be worried about either. Im so happy to hear this, I sure as hell am one of the lucky ones, and thanking my lucky stars. so the damage is clutch/flywheel and Iam getting a valve adjustment
Thanks H-T
Old Jun 3, 2005 | 12:09 AM
j4dlsd's Avatar
So I finally got my caR back from the dealer, and a new clutch/ resurfaced flywheel, waterpump/timing belt ( did it while it was all open to save me the trouble later down the road) and a valve adjustment later.... leaves me with an empty wallet. But I am so happy that things turned out this way and not the infamous blown valvetrain route!
Thanks again for all of you who helped out
Old Jun 3, 2005 | 12:44 AM
Kavehman's Avatar
i checked the compression on mine when i bought it and it was about 255.
Why are your numbers so low, do u know how they did the test. I guess it was probably on a cold engine
Old Jun 3, 2005 | 05:08 PM
j4dlsd's Avatar
Default Re: night at the local racetrack (Kavehman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kavehman &raquo;</TD></TR><TR><TD CLASS="quote">i checked the compression on mine when i bought it and it was about 255.
Why are your numbers so low, do u know how they did the test. I guess it was probably on a cold engine</TD></TR></TABLE>
I asked the same thing, they told me that thats the highest their tester is calibrated to. I guess some testers range from 160-200
Old Jun 3, 2005 | 06:50 PM
Tad's Avatar
Tad
yeah the lower number the better
sure 5% is where you want to be at..
but 15% and even comp results sounds like an engine that might not be the gnarlies R ever,
but it probly works just fine
Blindeye_03
May 7, 2010 09:56 PM
double helix
Dec 5, 2004 10:23 PM
TypeRKoncepts
Oct 12, 2004 04:15 PM
Mt3c
Mar 3, 2002 12:38 AM
Chip398193
Sep 5, 2001 02:37 PM
