Suspension & Brakes Theory, alignment, spring rates....
tires rubbing, please HELP
Old May 31, 2005 | 08:45 AM
87turdR's Avatar
Default tires rubbing, please HELP
I recently installed a set of Koni Specials on my '93 civic hatch. Befor the install i had stock Integra LS suspension bits and plenty of travel to clear the 205/60r-15s I have. Now they rub against the top of the wheel well when I hit a bump in a corner. This must stop. From what I understand, the 60 ratio sidewall is simply too tall, but it seems negligable to step down to a 50 ratio. Will this really stop the rubbing? Any suggestions?
Modified by 87turdR at 1:20 PM 5/31/2005
Old May 31, 2005 | 10:17 AM
00R101's Avatar
Default Re: tires rubbing, please HELP (87turdR)
Did you transfer the brake bracket from the old shocks to the Konis?
Old May 31, 2005 | 03:52 PM
bottlefed13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 87turdR &raquo;</TD></TR><TR><TD CLASS="quote">I recently installed a set of Koni Specials on my '93 civic hatch. Befor the install i had stock Integra LS suspension bits and plenty of travel to clear the 205/60r-15s I have. Now they rub against the top of the wheel well when I hit a bump in a corner. This must stop. From what I understand, the 60 ratio sidewall is simply too tall, but it seems negligable to step down to a 50 ratio. Will this really stop the rubbing? Any suggestions?
Modified by 87turdR at 1:20 PM 5/31/2005</TD></TR></TABLE>
ya...just switch to 195/50/15 and the rubbing should stop. i had the same problem before. i couldn't make a u turn without rubbing until i changed my tires. the 205 in the front might be too wide for your drop.
Old May 31, 2005 | 06:45 PM
cruizinmax's Avatar
195/55-15 is the correct size. 205/50-15 is the plus zero size. 205/60-15 is too big, it is almost one inch taller. The rubbing will stop with correct size tire. If you like the wrong size tire on your car I believe you can raise your car up a little with the konis.
Old May 31, 2005 | 07:56 PM
87turdR's Avatar
Default Re: tires rubbing, please HELP (00R101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00R101 &raquo;</TD></TR><TR><TD CLASS="quote">Did you transfer the brake bracket from the old shocks to the Konis? </TD></TR></TABLE> How would that stop my tires from rubbing? But to answer... No but i did zip-tie them well
Old May 31, 2005 | 08:00 PM
87turdR's Avatar
Default Re: (cruizinmax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cruizinmax &raquo;</TD></TR><TR><TD CLASS="quote">205/50-15 is the plus zero size.</TD></TR></TABLE> Please explain "plus zero size" to me.
Forgot to mention I am runnigng Voghtland (sp?) lowering springs (2" drop all around) and the spring seat is set as high as it will go on the Konis.
vartok
20
Mar 21, 2014 11:27 AM
Ladiesx3Me
Suspension & Brakes
11
May 17, 2008 11:01 AM
Rahxephon
Suspension & Brakes
13
Feb 14, 2007 11:49 AM
tvrsir
Oct 23, 2005 08:16 AM
Understeer
38
Aug 9, 2005 09:57 AM
