Swap trouble
I have a 92 civic si hb. I can install the motor myself, but the wiring part I am clueless. I was wondering is there a company out there that does plug and play for the harness for my car. Oh and I am doing an ls/v-tec is there a site that i can figure out how to run the oil lines.
please help!!!!!
please help!!!!!
If you have a 92 SI hb then your wiring is already taken care of by honda. Your d16z6 (sohc vtec) has all the connectors you need to run an OBD-1 b-series vtec motor. The vtec solenoid, vtec pressure switch and o2 sensor (4-wire) are all there. The only wire you will have to add is the knock sensor if you use an ecu that looks for the sensor (pr3(rare jdm obd-1),p30,p72,p73...ect). The P28 that you have in your car now will, if you chip it, will run the ls/vtec without problem and the knock sensor would be optional. I wish I had the SI when i did my swap but i had to go off the cx trim which made me have to wire up the everything mentioned above. You harness is esstenially a plug and play harness. Good luck with your swap.
Why are you running oil lines? Are you turbo?
