Wiring map sensor from 92LS IM to Type R thottle body map sensor
Old May 31, 2005 | 06:48 AM
j-robsDA's Avatar
Default Wiring map sensor from 92LS IM to Type R thottle body map sensor
I am trying to figure out which plug goes where on my swap. I am useing my LS engine harness and I have a Type R IM. The type R has the map sensor on the Throttle body and the LS had it on the IM. The LS had a 2 wire plug to my knowledge and the "R" has a 3 wire plug. Unless I am getting the throttle position sensor and the Map sensor mixed up on the new "R" throttle body. as they both use the grey plug and they both connect right up to it. I am in a world of confusion over this. Some help would be fabulous.
I also have a gm 3-bar map sensor so do I even need to bother with the sensor on the throttle body. If not then what the hell do I do with the old LS sensor wires?
Modified by j-robsDA at 10:31 AM 5/31/2005
Modified by j-robsDA at 11:08 AM 5/31/2005
thedudefromjerz
Feb 8, 2008 09:41 PM
SuicideSlide
May 16, 2005 01:47 PM
.Hookedonhatch.
Mar 2, 2004 09:34 PM
comptechgsr2000
May 8, 2002 03:53 PM
