HELP: Broken motor mount?
Okay, so when I press the gas or break, or go over a small bump, I hear a loud click-pop sound, I can even feel the click sometimes with my feet on the floor and such. Popped the hood, and revved the engine with the throttle cable, and I noticed the engine torquing a little bit, does the engine torque anyways or do I have a broken motor mount?
the engine will move a little when the throttle is pressed, that is normal. I wouldn't say you have a broken motor mount, that would cause more vibrations at idle but would smooth out once moving. I would check for something loose in the front suspension. Maybe an axle, ball joint, sway bar, ect. Thats probably where your problem is.
Rocks
11
Jul 23, 2004 11:19 AM
