H22a H22 Dyno Stock i/h/e IM and basemap 197.7whp
Old May 31, 2005 | 06:25 AM
Adam.'s Avatar
Default H22a H22 Dyno Stock i/h/e IM and basemap 197.7whp
I already posted this is the Prelude forum, but I figured most of the all motor guys probably don't go in there so here it is:
https://honda-tech.com/zerothread?id=1261618
Fake J's Racing Intake w/ K&N Filter
EuroR Intake Manifold
Hondata IM Gasket
Balance Shaft Belt Removed
AN-R Header with 2.5" Street Collecter
Mandrel Bent KTeller Exhaust 2.5"
Magnaflow ES Oval Style Muffler 2.5"
Tuned via Uberdata or Crome
Dynojet
4th gear pulls
This was a baseline pull, no tuning. I have a basemap from a similarly setup h22a with i/h/e that I used for this run. It was a dyno day in South Florida. It was hot and packed and there was no time to make any corrections to anything. I have a lot to pick up mid range and I'm sure I could squeak out over 200whp up top. All in all, it's a great baseline run before I install the rocket motorsports h22 regrinds I have sitting around here. https://honda-tech.com/zerothread?id=1253111
EDIT: About STD vs. SAE, it was a packed dyno day and they were taking the time to change the output settings to SAE corrected. I will assure you of this though, it was a hot, muggy South Florida day and any corrections would've only made the numbers higher.
Old May 31, 2005 | 06:28 AM
Phatch99's Avatar
Default Re: H22a H22 Dyno Stock i/h/e IM and basemap 197.7whp (DarkKnight1)
nice #'s
Old May 31, 2005 | 08:42 AM
VSBB6's Avatar
Default Re: H22a H22 Dyno Stock i/h/e IM and basemap 197.7whp (Phatch99)
Thats impressive for a stock motor, do you think most of the gains is made from the header?
Old May 31, 2005 | 09:07 AM
BolivianDc2's Avatar
Default Re: H22a H22 Dyno Stock i/h/e IM and basemap 197.7whp (VSBB6)
nice numbers, do you have a pic of the euroR mani on your engine?
Old May 31, 2005 | 09:13 AM
Adam.'s Avatar
Default Re: H22a H22 Dyno Stock i/h/e IM and basemap 197.7whp (BolivianDc2)
Modified by DarkKnight1 at 8:04 AM 6/2/2005
Old May 31, 2005 | 09:37 AM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VSBB6 &raquo;</TD></TR><TR><TD CLASS="quote">Thats impressive for a stock motor, do you think most of the gains is made from the header? </TD></TR></TABLE>
Can't say for sure. I didn't do before and after testing. I'd say it does a great deal to help the motor breathe.
Old Jun 4, 2005 | 09:28 AM
h22slohatch's Avatar
how much was your header dark night?is that rage header?anyways nice motor,cant wait to see your dyno runs w/your cams!
Old Jun 4, 2005 | 09:29 AM
Default Re: H22a H22 Dyno Stock i/h/e IM and basemap 197.7whp (h22slohatch)
oh are you using stock valvetrain or RM?
Old Jun 5, 2005 | 06:03 AM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22slohatch &raquo;</TD></TR><TR><TD CLASS="quote">how much was your header dark night?is that rage header?anyways nice motor,cant wait to see your dyno runs w/your cams! </TD></TR></TABLE>
That is the AN-R mild steel h22/civic header w/ 2.5" Street Collector. I can't wait to see them either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22slohatch &raquo;</TD></TR><TR><TD CLASS="quote">oh are you using stock valvetrain or RM?</TD></TR></TABLE>
With the regrinds, I'm using the Rocket Motorsports valvetrain.
Jsherrod
Jun 14, 2015 09:35 AM
JDMRice
Jul 22, 2006 06:29 AM
S2k ALeN
Aug 28, 2005 11:30 AM
xludexgenx5
Dec 31, 2004 12:45 PM
