engine code 43 on 93 accord
Old May 31, 2005 | 04:38 AM
Y8500rpm's Avatar
New User
Default engine code 43 on 93 accord
i'm still getting a engine code 43 on my 93 accord EX. i changed the O2 sensor, my injectors and a new fuel pressure regulator. i was having this problem, when i accelerate the car moved fine then it would hesitate and once i release the gas pedel and accelerate again its fine. i disconnected the battery and the check engine light comes back with the same code. . any suggestions? i need to get this fixed ASAP since i have a emissions test due in June.
Old May 31, 2005 | 04:42 AM
v4lu3s's Avatar
RTFM
valve adjustment, exhasut leak between the engine and o2 sensor, or bad wiring can cause that code, as well as it being too rich/too lean fuel conditions. chances re though its one of the otehr things rather than too rich/lean.
bdr_one
Nov 25, 2014 03:22 PM
gazaaccord
Sep 27, 2013 03:27 PM
Nonio
Aug 29, 2010 06:22 AM
Y8500rpm
May 29, 2005 06:43 AM
Y8500rpm
Jan 27, 2005 06:07 AM
