Wrong place for this thread....? prob...but does anyone know the best way to mount CF front lips wit
Old May 31, 2005 | 12:35 AM
turbo95eg6's Avatar
Default best way to mount CF front lips without the epoxy cracking?
Prob the wrong section for the post, but is their a way to instal lips without cracking the sides of the lip...?
Im sure you guys with CF front lips/abs non urethane lips have experienced their lip cracking while instal....You know, the corners, where it hooks up onto the sides of the bumpers...? Usualy the epoxy gives away from the tension, not the CF...Ive had numerous lips, my current VIS one did the same...
Im instaling another lip again, this time i want to do it right..preferably without crackin the sides.....any suggestions...?
Old May 31, 2005 | 12:43 AM
ukdm crx's Avatar
Default Re: best way to mount CF front lips without the epoxy cracking? (turbo95eg6)
Epoxy? Just drill a hole and use a bolt, nut and washer.
Old May 31, 2005 | 12:46 AM
turbo95eg6's Avatar
Default Re: best way to mount CF front lips without the epoxy cracking? (ukdm crx)
no no....i meant the lip is always so ******* tight on the bumper...you hook up one end, and when you try to hook up the other end its soo tight that the clear epoxy starts to crack....
Inextricabledrvr
Paint and Body
Jun 27, 2008 06:49 PM
jacob1217
Mar 26, 2007 12:28 PM
mouseghb
Feb 18, 2005 02:32 PM
eug_34
Oct 22, 2004 04:55 PM
JadeDM
Jan 15, 2004 07:21 PM
