Launched at the strip and....
Old May 30, 2005 | 09:33 PM
AaronJ's Avatar
Default Launched at the strip and....
I went to the dragstrip tonight with my b16 hatch. On my 1st run I launched and got some bad wheelhop, then driving back to the pit area I noticed that the car felt really darty. I got out and noticed the wheels were toe'd out really bad.
I just lowered the car about 2 1/2 inches 3 weeks ago, the toe was really bad and then I got a full alignment, but after that launch it messed the toe up really bad.
What could have caused this? Is it possible for something to have broken in the rack and pinion?
TIA
Old May 30, 2005 | 10:08 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Launched at the strip and.... (AaronJ)
front radius rod bushings are smoked
Old May 31, 2005 | 04:43 AM
AaronJ's Avatar
so the radius rod arm bushings that are in the front crossmember are shot? If thats the problem that's great, cause I have traction bars waiting to be put on.
I'll have to jack it up today and see if that's it
Old May 31, 2005 | 12:37 PM
AaronJ's Avatar
Default Re: (AaronJ)
anybody else?
Old May 31, 2005 | 08:12 PM
AaronJ's Avatar
It wasn't the front radius rod bushings. I noticed a boot on my tie rod was torn, looks like it was torn for a while. I think something slipped or stretched in the tie rod somewhere...not really sure what to replace or how to replace it
Anybody else have this problem before?
Old May 31, 2005 | 08:14 PM
ALLMOTA92EG's Avatar
after you find out the problem you should invest in a camber kit.
Old Jun 1, 2005 | 12:04 PM
AaronJ's Avatar
Default Re: (jdm92civichb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm92civichb &raquo;</TD></TR><TR><TD CLASS="quote">after you find out the problem you should invest in a camber kit.</TD></TR></TABLE>
I have an ingalls camber kit, my camber is dead at zero.
I don't know anything about inner and outer tie rods, but the deal with the ball and socket and about a 4 inch rod with threads on it prolly neads to be replaced...i think the threads that go into the actual rack itself slipped
Old Jun 2, 2005 | 03:19 PM
AaronJ's Avatar
I'm just gonna go ahead and get a complete reman rack and pinion, found it for 150, 120 with the cores. Comes with new inner tie rod ends and the pinion, pre assembled...hell of a deal
Modified by AaronJ at 8:10 PM 6/2/2005
busyychild
Jan 3, 2008 01:30 PM
Blaze45
May 15, 2004 10:54 AM
2camsaam
May 1, 2002 07:34 AM
jonas
Jan 24, 2002 08:31 AM
