CEL Code 43 Fuel Supply System 90 Integra?
Old May 30, 2005 | 09:12 PM
90AcuraIntegra04's Avatar
Default CEL Code 43 Fuel Supply System 90 Integra?
Alright i have been getting code 43. I have not ever noticed a diff. of performance but i could be wrong. When i start my car and start to drive it will not be on, soon or a later it will turn on and never go off. I get code 43 so i replaced my fuel filter and that did not do that. I dont notice a difference in power when it is on then off but i may just not notice it. My fuel pump works fine. I heard it could be the o2 sensor. I just put one on a few months ago but recently i had a timing problem and was shooting flames out of the exhaust so i dont know if that friend it Anyone got a quick and easy answer? THanks
Old May 30, 2005 | 09:14 PM
Default Re: CEL Code 43 Fuel Supply System 90 Integra? (90AcuraIntegra04)
if it is the o2 sensor, could that cause me to run rich and get black smoke up on the back of my car and at high rpm's? Thanks
Old May 31, 2005 | 03:54 AM
FredoSP's Avatar
Id say its the O2, did you get an OEM replacement? Did you rest the ECU after you installed the O2 to clear the code?
How do u know that ur timing is off? Did you play with the dizzy? Get the timing checked out first!!
Old May 31, 2005 | 08:03 AM
My timing belt slipped and majorly screwed up the timing so i was burning richer then a jet airplane. I thought that could have fryed it. Ill get a new o2 sensor asap. Thanks
Old May 31, 2005 | 08:07 AM
s2kdre's Avatar
Default Re: (90AcuraIntegra04)
thats the same code i get but only if i get on it when the car is cold.
Old May 31, 2005 | 10:37 AM
Arsenal's Avatar
Default Re: (jdmhonda)
You should search. I have posted the answer to this question numerous times now, its the O2 sensor.
When the CEL Kicks in your car enters limp mode, ie. as rich as possible at all times. Get it checked and fixed.
Old Oct 12, 2008 | 08:41 AM
jnseames's Avatar
Default Re: (Arsenal)
Just so you know the answer that it is the 02 sensor is not always the right answer. It seems to be the most common reason for the code but its not always the problem.
anything that causes the o2 sensor to read incorrectly could cause the light to come on.
basically anything that could cause the vehicle to run too rich or too lean. Get a manual
and perform the tests first. Unfortunately I have the same code coming on and instead
of just doing the tests I started throwing parts at it. still have the code coming on. the o2 sensor was the first thing I replaced. My advice is test everything before replacing parts.
SlowB20z
Engine Management and Tuning
Dec 28, 2012 09:12 AM
civiccarbuff
Sep 18, 2008 08:29 PM
tonyguns
Apr 21, 2008 03:33 PM
Rudelude22
Sep 29, 2005 10:20 AM
PhilStubbs
Jan 22, 2005 11:20 AM
