Ashy Weld
Old May 30, 2005 | 08:49 PM
AZNracerx1989's Avatar
Default Ashy Weld
When I weld with my stick welder... It makes a big black ash... when i take a hammer to test it, it breaks the black ash like its nothing and leaves me with strong weld inside...
what is the problem??? i made a bigggggg weld on a joint.. waited 20 seconds.. and still, i could break it with my hands
Old May 30, 2005 | 11:33 PM
RCautoworks's Avatar
Default Re: Ashy Weld (AZNracerx1989)
Sounds like your talking about slag, thats normal with stick welding
Old May 31, 2005 | 12:23 AM
kawgomoo's Avatar
Default Re: Ashy Weld (90blackcrx)
that coating is slag, its what keeps the weld oxygen free as it cools. this is why in mig welding you use a shielding gas with obviously dissiptes and leaves no nasty buildup like you get from the flux that is burnt during arc welding which leads to the production of slag.
Old May 31, 2005 | 06:07 AM
david@didrace.com's Avatar
I'd suggest at least reading a book on welding before diving in. Sounds like you have no clue what you're doing, and that's not too safe.
Old May 31, 2005 | 07:13 AM
Default Re: Ashy Weld (backpurge)
I saw a weld on ebay for 120 plus shipping.. a MIG one that is only 90 amps or something... will it be better than a 200 dollar stick welder?
the lincoln electric AC-225
Old May 31, 2005 | 09:43 AM
CRXDrew's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge &raquo;</TD></TR><TR><TD CLASS="quote">I'd suggest at least reading a book on welding before diving in. Sounds like you have no clue what you're doing, and that's not too safe. </TD></TR></TABLE>
Read up man. Welding has been around for a while and there are countless books on the subject. I'm sure your local library will have plenty of bathroom reading material.
PhilStubbs
Welding / Fabrication
May 1, 2013 04:31 PM
MindLess311
Jan 21, 2007 04:48 PM
qksl2
Mar 11, 2005 10:21 PM
LostCRX
25
Jan 30, 2005 12:22 PM
SymphonyX
Apr 13, 2003 07:43 PM
