What do i need to swap a gsr into a ek?
Old May 30, 2005 | 07:42 PM
BoOsTiN Dc2's Avatar
Default What do i need to swap a gsr into a ek?
What is needed to swap a 94 gsr motor into a 96 ek hatch? Like what kind of mounts i need and engine harness? Everything else should work from the gsr motor right?
Old May 30, 2005 | 07:45 PM
e jay one's Avatar
Default Re: What do i need to swap a gsr into a ek? (tRaCeBuStAbUsTeR)
you know this wont be legal in ca right? did you search?
Archidictus's Avatar
Unceasing Measure
OBD1 >>> OBD2 conversion harness, mounts from the B18C to combine with the EK stockers, the GSR shift linkage, GSR axles and the GSR ECU.
Old May 30, 2005 | 08:05 PM
kid-crx's Avatar
u need the help of a professional lol
Old May 30, 2005 | 08:13 PM
Unceasing Measure
Default Re: (supportRhondas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supportRhondas &raquo;</TD></TR><TR><TD CLASS="quote">u need the help of a professional lol</TD></TR></TABLE>
Maybe he does, but many of the rest of us don't .
Old May 30, 2005 | 08:16 PM
Patron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR &raquo;</TD></TR><TR><TD CLASS="quote">What is needed to swap a 94 gsr motor into a 96 ek hatch? Like what kind of mounts i need and engine harness? Everything else should work from the gsr motor right?</TD></TR></TABLE>
Don't do it.
It's illegal everywhere. However if you choose to do it, you'll need the B-Series mounts. You'll need B-series linkage, you'll need the EK wiring harness, adding VTEC pressure, solenoid, and knock lines (maybe). You'll need obd2 injectors, obd2 dizzy, a secondary o2. I dunno, I can't remember everything else. Just off the top of my head. I haven't done a B-swap in a few months.
Old May 30, 2005 | 08:35 PM
Default Re: What do i need to swap a gsr into a ek? (ptran13)
im not worried about being legal or not since my teg is a fully built lsv turbo w/out cat. and i wont pass smog if the world depend on it. I've just forgot which mounts and harness would make it easiest for swapping in a ek so i dont have to have a big downtime. supportRhonda i think your the one that really needs professional help
Old May 30, 2005 | 09:06 PM
zeroek's Avatar
Here is what I have heard. You can use your stock harness and repin/lengthen wires that you'll need. I do believe a single cam vtec harness will work with a P72 (gsr ecu) but some wires still need lengthened.On a GSR I'm not sure on the mounts. For a b16 you gotta use the 99 -00 rear mount so I don't if it's the same for the GSR motor.
Old May 31, 2005 | 05:41 AM
jayare05's Avatar
Default Re: What do i need to swap a gsr into a ek? (zeroek)
what makes it so illegal?
Old May 31, 2005 | 06:45 AM
RaYnE's Avatar
cali and their strict emissions..
Old May 31, 2005 | 06:46 AM
SlepT ej6's Avatar
Default Re: What do i need to swap a gsr into a ek? (jayare05)
I just finished my swap last nite, Mounts needed:
-99-00 SI rear bracket
-99-00 SI Driver side mount (block attached)
-GSR Front tranny mount w/ civic studs (or 99-00 SI mount)
-A/C -- 99-00 SI mount or 93-95 Del sol (i think those are the year for the del mount)
Others:
B series linkage
B series axles and halfshaft
anything else just check this out: http://www.phear7imports.net/trey/6gen/
Old Jun 1, 2005 | 07:41 PM
Default Re: What do i need to swap a gsr into a ek? (SlepT ej6)
on the driver side upper mount can i reuse the stock mount? it looks like it'll work but im not positive. So the wire harness i can reuse the stock one but just repin it right? OBD2 dizzy, starter and prob a jumper harness with the obd1 ecu?
Old Jun 3, 2005 | 11:50 AM
SlepT ej6's Avatar
if you mean the mount on the frame yes u can use that stock one... and as per the wiring, i used my dx harness and its running fine, repining is a must and b series starter and obd2 b series alternator as well!
want2drive
Jun 14, 2011 10:11 AM
Siegfried
May 31, 2007 10:33 AM
HitEm'Up
Aug 27, 2005 09:30 PM
Petah
Mar 6, 2003 06:08 AM
