how do you tell the diffrence between resistor and non resistor injectors
Old May 30, 2005 | 07:13 PM
downeyballz's Avatar
Default how do you tell the diffrence between resistor and non resistor injectors
a freind of mine has a 91 teg with a gsr swap. the people that did the swap are kinda shady and we dont know what injectors are in the motor the 91 ls which use a resistor box or the newer not resistor gsr ones that came with the motor. the car doesnt feel as fast as it should be when compared with other gsr swapped cars ive been in so im thinking this could have something to do with it. so i was wondering if ther is anyway to tell the diffrence between the two injectors as far a marking on them or maybe voltage at the clips?
Old May 31, 2005 | 05:46 AM
machine4321's Avatar
youll have to measure them with a multi meter and see what resistance they are ...
low is usually around 3.00
and high is around 13.00
CivicxTree754
Aug 26, 2008 12:48 PM
SFlCrx
Mar 21, 2007 05:48 PM
downeyballz
Jun 1, 2005 02:47 AM
downeyballz
May 30, 2005 08:10 PM
rbf351
Nov 2, 2002 10:05 PM
