02+ ep or rsx Cluster in my 98 ek?
Old May 30, 2005 | 07:03 PM
purple98ek's Avatar
Default 02+ ep or rsx Cluster in my 98 ek?
I am just wondering if anyone has attempted to swap a 02+ civic cluster or a rsx cluster into a 96-00 civic......if so, how difficult is it? and how much rewiring is involved?......thanks
Old May 30, 2005 | 07:23 PM
Archidictus's Avatar
Unceasing Measure
Default Re: 02+ ep or rsx Cluster in my 98 ek? (purple98ek)
Been done, custom mounting, complete rewiring .
Old Jun 3, 2005 | 08:27 AM
nota-eg's Avatar
Default Re: 02+ ep or rsx Cluster in my 98 ek? (Archidictus)
As far as I know the tach, fuel, and random things like turn signals wire right up, but the speedo and temp gauges need a lot of modifications that are still being worked out.
The 92-00 civic VSSs are the same. They operate at a much lower frequency than the S2K, RSX, and newer civics. Like you will get a readout of 15hz from the old sensors at a certain speed, while the S2k or RSX cluster will give you a readout of 500+hz.
I was doing a lot of reading and basicially what it comes down to is you need a modulator to multiply the VSS signal from the 92-00 VSS so the S2K speedo can read it correctly.
Guys that are working on it said that they get readings of 1 or 2 mph on the cluster when they're doing about 90.
<jdm_love>
Jan 12, 2010 11:59 AM
swirve1
Jan 7, 2010 09:54 AM
Aznsensation
Mar 27, 2009 10:14 AM
