When did jdm ITR's come with 5 bolt?
Old May 30, 2005 | 06:57 PM
btcca4's Avatar
Default When did jdm ITR's come with 5 bolt?
Im looking at a engine swap and it has jdm 4 bolt..
Is this motor a 96 spec?? Or did 97's have the same brakes too?
Old May 30, 2005 | 07:02 PM
Shalom's Avatar
Default Re: When did jdm ITR's come with 5 bolt? (btcca4)
The 98 "spec" had the switch to 5x114.3 late 95-97 had the 4x114.3.
Are you looking at a front clip I presume?
Old May 31, 2005 | 11:31 AM
mugenracer's Avatar
They started building the 98spec ITR in late 1997. 96spec ITRs with 4x114.3 lugs were built from august 1995 to late 1997, so yes a 1997 will have 4 lug wheels/brakes
Old Jun 5, 2005 | 12:52 PM
Cone's Avatar
Default Re: (mugenracer)
did they change to the 36mm hubs for 98+?
Old Jun 5, 2005 | 02:24 PM
b16pwrdeg's Avatar
Default Re: (Stealth 95 GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealth 95 GS-R &raquo;</TD></TR><TR><TD CLASS="quote">did they change to the 36mm hubs for 98+?</TD></TR></TABLE>
Yes....I have a 98+ JDM ITR 5 Lug conversion on my civic and I had to use the 36mm spline axles.
jdm_dc_199
Jan 25, 2020 10:08 AM
l2p
Jun 11, 2004 07:27 AM
fasthonda
Nov 30, 2003 08:01 PM
B18Redline
Jun 12, 2003 11:39 AM
oem
10
Jan 27, 2003 08:53 PM
