tranny fluid how to?????
Old May 30, 2005 | 06:15 PM
bbrian's Avatar
Default tranny fluid how to?????
i was wondering how to put tranny fluid in a stock dx hatch is a 5 speed tranny cable thanks ....
Old May 30, 2005 | 06:19 PM
JODYG35950's Avatar
Default Re: tranny fluid how to????? (bbrian)
Easiest way I have found is to pull the fill plug on the tranny (the top plug close to the pass. axle) and then pull the gear unit on top were your spedo cable plugs in. Mine has a single 10 mm set screw in it. Remove that whole unit and you can put a trans. funnel in that hole and fill till fluid runs out the fill plug hole.
Old May 30, 2005 | 07:13 PM
PURPLETERROR aka BIGMATT's Avatar
drain trans, reinstall andtighten drain plug, remove reverse light switch, insert funnel, pour in 3 quarts of 10w30 or honda mtf, tighten reverse light switch. go for drive screaming bwaaaabmwaaaaaambwaaaa out the window
northkai3
26
Sep 29, 2013 11:53 AM
japanstar_ef9
Mar 13, 2008 04:25 PM
upinsmoke
Nov 19, 2006 09:20 AM
Adrian G. Aka JDMonkey
Oct 18, 2006 04:17 PM
pelotudo
Jul 21, 2002 02:33 AM
