HELP...rear brakes wont decompress..
Old May 30, 2005 | 05:48 PM
pennies_hatchie's Avatar
Default HELP...rear brakes wont decompress..
well, i just got done replacing the rear rotors and brake pads on my del sol vtec and now the car wont budge. for example, if you have it in nuetral and the ebrake down, you cant push the car back or forward. if you drive it, it smokes. its like the ebrake is on but its not. i pushed the ebrake cable in the rear and there is slack there. any help would be great.
Old May 30, 2005 | 06:32 PM
Default Re: HELP...rear brakes wont decompress.. (pennies_hatchie)
help, my rear brakes are locked
Old May 30, 2005 | 06:39 PM
nocturnaldragon's Avatar
If there rear disk you have to turn the puck down clockwise not compress it like you would on the front set.
Old May 30, 2005 | 07:08 PM
Default Re: HELP...rear brakes wont decompress.. (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">If there rear disk you have to turn the puck down clockwise not compress it like you would on the front set.</TD></TR></TABLE>
im not understanding. this is what i did...
1. take off rims
2. take off old rotors
3. take off calipers
4. remove pads
5. put new rotors on
6. hammer the pistons on the calipers in
7. put the pads on
8. tighten everything back
now the rear wheel wont budge..its like its lock. the ebrake is also down. help if you know what i did wrong. thanks
Old May 30, 2005 | 07:16 PM
notfastenough's Avatar
The pistons you hammered in also have to be screwed in. That is why it has those notches in them. Your pistons are not decompressed the way they should be.
Should have done a smidgin of research before doing this. Oh well.
Here's a link on what you should do from the sig of nocturnaldragon
https://honda-tech.com/zerothread?id=898904
Old May 30, 2005 | 07:19 PM
Default Re: (notfastenough)
is there a way to fix it other than buying new calipers?? also the link you have is a how to remove a crank pulley
Old May 30, 2005 | 07:21 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie &raquo;</TD></TR><TR><TD CLASS="quote">
1. take off rims
4. remove pads
7. put the pads on
8. tighten everything back</TD></TR></TABLE>
Wow. A.) never hammer brake calipers or pistons, ever. B.) rear disc brakes use a screw-type piston to actuate the pads.
You probably destroyed both calipers. Remanufactured ones from Autozone are about $70 each with core . That sucks, broham.
Old May 30, 2005 | 07:24 PM
e jay one's Avatar
wrong link here you go
https://honda-tech.com/zerothread?id=935087
and yea i dont think you should hammer anything you can also use a c clamp.
Old May 30, 2005 | 07:27 PM
Default Re: HELP...rear brakes wont decompress.. (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
You probably destroyed both calipers. Remanufactured ones from Autozone are about $70 each with core . That sucks, broham.</TD></TR></TABLE>
damit
Old May 30, 2005 | 07:28 PM
Default Re: (e jay one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one &raquo;</TD></TR><TR><TD CLASS="quote">wrong link here you go
and yea i dont think you should hammer anything you can also use a c clamp.</TD></TR></TABLE>
and i tried the c-clamp on the rear (didnt know i had to turn it) and of course it didnt go in, so i used the hammer..stupid me
Old May 30, 2005 | 07:29 PM
Unceasing Measure
Default Re: (pennies_hatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie &raquo;</TD></TR><TR><TD CLASS="quote">and i tried the c-clamp on the rear (didnt know i had to turn it) and of course it didnt go in, so i used the hammer..stupid me</TD></TR></TABLE>
Not stupid: just inexperienced. Hey, you made the piston go in, right?
Unfortunately, the rear calipers are pretty sensitive and you can destroy them very easilly. Yours are almost definately toast
Old May 30, 2005 | 07:36 PM
Default Re: (Archidictus)
ill take off the calipers and see if they're gone or not
Old May 30, 2005 | 07:39 PM
e jay one's Avatar
yea dont feel bad i tried the c clamp thing on my moms vr6 with rear disc fortunatly i didnt force it and figured it out.
Old May 30, 2005 | 07:46 PM
try sticking a piece of metal in them once you remove them and step on the brake. So you dont pop the piston out and see if they still work. Im pretty sure there junk now, you can allways take them apart and see if its all good. Ive never taken a brake apart before so im not sure whats all involved with that.
Jim Dan
Honda Civic (2001 - 2005)
Apr 17, 2013 12:42 PM
kevinm1981
Aug 3, 2009 02:24 PM
babzog
May 22, 2008 09:49 PM
blue_hatch
Suspension & Brakes
Dec 17, 2007 05:48 PM
LSVTEC 91 Civic
Honda Fit
37
Nov 15, 2007 05:52 AM
