What Swaps Can I Do?
Old May 30, 2005 | 05:27 PM
97civicsedan's Avatar
B A N N E D
Default What Swaps Can I Do?
What swaps can i do for my 89 ef civic hatch with a automatic trans. But i do not want to convert it to a maunual transmission. Please let me know
Old May 30, 2005 | 05:37 PM
R_type's Avatar
Default Re: What Swaps Can I Do? (97civicsedan)
What Swaps do you want to do is the real question ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ??????????????????????????
Old May 30, 2005 | 06:19 PM
B A N N E D
I would like to do any b series i can but arew they available with automatic transmissions and will they fit???
Old May 30, 2005 | 10:53 PM
Immanuel's Avatar
dont even bother to do a swapp on a Automatic sell that bitch and get stick and then either buy a B16 or an LS- VTEC
Old May 31, 2005 | 04:09 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicsedan &raquo;</TD></TR><TR><TD CLASS="quote">I would like to do any b series i can but arew they available with automatic transmissions and will they fit???</TD></TR></TABLE>
First of all, your typical B-series mount kit will not accommodate an automatic transmission. Secondly, the B-series automatic transmission is HUGE. So as a best case scenario, you will have to do TONS of custom fabrication to do an automatic B-series swap. On the other hand, there just might not be enough room. The very end of a YS1 manual transmission case just fits under the passenger side frame rail. An automatic is MUCH bigger and might not fit there. Seriously, if you are hellbent on doing an automatic, you might be stuck with D-series.
Old May 31, 2005 | 07:56 AM
silver88crxsi's Avatar
Default Re: What Swaps Can I Do? (StorminMatt)
LOL ditch the automatic
Get a manuel and then thake a visit to Hmotorsonline.com
Old May 31, 2005 | 08:05 AM
DohcVtecCrx's Avatar
Default Re: What Swaps Can I Do? (silver88crxsi)
I looked into swapping a b series auto into my wifes car, she loves auto, but the b series mount kit will not work with auto trannies. SO now your stuck with a zc dohc or sohc or the jdm d15b.
BTW the b series auto trans is the same size or damn close to the manual trans. There is no real diffrence in size and there is no diffrence in da engine bays either.
Old Jun 2, 2005 | 04:58 AM
Default Re: What Swaps Can I Do? (DohcVtecCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcVtecCrx &raquo;</TD></TR><TR><TD CLASS="quote">BTW the b series auto trans is the same size or damn close to the manual trans. There is no real diffrence in size and there is no diffrence in da engine bays either.</TD></TR></TABLE>
Not true. The manual transmission tapers down quite a bit long its length. But the automatic transmission remains pretty much the same size as the bell housing along the entire length of the transmission. While the manual transmission is more conical, the automatic transmission is more cylindrical.
As far the DA engne bay, it is indeed the same size for the automatic models as for the manual models. But regardless, it is bigger than an ED/EF engine bay.
Old Jun 2, 2005 | 05:04 AM
drussell4801's Avatar
97civicsedan,
without knowing your power goals, its difficult to suggest anything.
If you want to stay automatic, you really shouldn't bother going b series, as it will not perform at all, and will not be worth the time or the money; not to mention the problems with the mount kits which have already been addressed above.
I say get a dual cam jdm zc motor and throw it in there with your stock trans. Motor is $500. Low mileage 130hp motor for $500 is decent.
If you want a racecar, you have to swith to manual, plain and simple.
You will have to decide if you want to keep the car in a somewhat stock form or if you want to go 'all out.'
Old Jun 3, 2005 | 01:11 AM
Default Re: What Swaps Can I Do? (drussell4801)
Another possibility would be SOHC VTEC. This will mate up with a stock automatic as well. And you can run it with a stock automatic P28 ECU.
Old Jun 4, 2005 | 02:48 AM
oh yeah, i didn't mention what ecu he'd have to run with the dual cam zc + auto trans.
He would have to get an 88-89 automatic integra ecu.
97civicsedan
May 31, 2005 04:05 AM
Rywire
Dec 12, 2004 09:30 PM
XyKo
Nov 17, 2004 10:55 AM
Ash J. Williams
34
Oct 29, 2004 10:40 AM
fcuked
May 17, 2003 11:38 PM
