rpm/hp limits of an ITR oil pump?
Old May 30, 2005 | 04:52 PM
Boostage's Avatar
Default rpm/hp limits of an ITR oil pump?
what are stock ITR pumps good for?
Old May 30, 2005 | 04:54 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: rpm/hp limits of an ITR oil pump? (Boostage)
the oil pump gears are the weak link... i'll be using an itr oil pump on my 2.1 liter ls/vtec.
im probably gonna send the pump out to endyn and let them modify it..
Old May 30, 2005 | 04:56 PM
DRIVENRacing's Avatar
my endyn pump gave out after 90 miles
Boostage's Avatar
Default Re: rpm/hp limits of an ITR oil pump? (wantboost)
weird, I hear so many bad things about aftermarket gears, especially the prodrive.
Old May 30, 2005 | 05:33 PM
Boostfed's Avatar
New User
Use a stock ITR/GSR pump and gear or get a Toda Oil pump gear. Local guys here have had good luck with them even after breaking stock ones. There is a nother company coming out with a new pump gear already installed in a new pump for our Hondas, cannot say just yet but will be out and should work WELL! I may prototype one.
Geoff just make sure to run a new pol pump and make sure everything is balance and your clutch is good too, too much harmonics and high rpm kills them(well High RPM with added harmonics if it has not been balanced)
Old May 30, 2005 | 05:37 PM
T4eg's Avatar
Default Re: rpm/hp limits of an ITR oil pump? (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote"> make sure everything is balance, too much harmonics and high rpm kills them(well High RPM with added harmonics if it has not been balanced)</TD></TR></TABLE>
Old May 30, 2005 | 05:41 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: rpm/hp limits of an ITR oil pump? (T4eg)
i'll be running a blanced and knife edged crank, with an act 8lb fly2heel (or how ever much they weigh) 6-puck act xtreme clutch and either a ctr n1 crank pulley or a fluidampr, all depends on how much money i have left, lol
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">i'll be running a blanced and knife edged crank, with an act 8lb fly2heel (or how ever much they weigh) 6-puck act xtreme clutch and either a ctr n1 crank pulley or a fluidampr, all depends on how much money i have left, lol</TD></TR></TABLE>
Get the Fluidampr DEFINATELY!
Old May 30, 2005 | 05:43 PM
wantboost's Avatar
Who is Mr Robot?
well, the cheapest ive found them is 350 shipped.. can you go any lower?
i also have to sell my itr water pump plus the n1 pulley, im running an electric one with an idler blockoff.. so if you know anyone that wants those two parts brand new, lemme know
Old May 30, 2005 | 06:18 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">well, the cheapest ive found them is 350 shipped.. can you go any lower? </TD></TR></TABLE>
Well worth it for the price. My N1 pulley killed my prodrive gear. Now stock ITR pump and Fluidampr from Arturbo. 600whp+ street car = no problems.
Old May 30, 2005 | 06:22 PM
11SEC CIV's Avatar
Default Re: rpm/hp limits of an ITR oil pump? (Blown90hatcH)
aren't gsr/itr oil pumps the same?
Old May 30, 2005 | 06:24 PM
Boostfed's Avatar
New User
Default Re: rpm/hp limits of an ITR oil pump? (12SEC CIV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12SEC CIV &raquo;</TD></TR><TR><TD CLASS="quote">aren't gsr/itr oil pumps the same?
Yes, I have checked the part #s at the dealership and they are the same
wantboost's Avatar
Who is Mr Robot?
Same part number, but as i understand it, the itr pumps are different and run at higher pressures
Old May 30, 2005 | 06:25 PM
tony1's Avatar
700+hp and 11k rpm, holding up fine for me...
Old May 30, 2005 | 06:38 PM
Boostage's Avatar
Default Re: rpm/hp limits of an ITR oil pump? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">700+hp and 11k rpm, holding up fine for me...</TD></TR></TABLE>
Old May 30, 2005 | 06:39 PM
Boostfed's Avatar
New User
YUP! As Tony states BUT also make sure to use a new one!!! Mine was old and tired out and exploded!
1stGENGSR
40
Jan 15, 2004 07:50 PM
bitr364
Aug 20, 2003 07:27 PM
KayOs
Jun 3, 2002 04:37 AM
Gonzo
Feb 14, 2002 12:57 PM
NC-B17A
Jan 17, 2002 12:00 PM
