EG Not starting after cap & rotor swap?!
Old May 30, 2005 | 04:38 PM
Tec Nine's Avatar
Default EG Not starting after cap & rotor swap?!
92 si w/ 95 GSR.
I should learn to never touch my car if it's running well. Anyway, I decided to get crazy and swap in new plugs, cap & rotor. I put in the plugs, tested and it started fine. I put on the new cap and it started fine (Borg-Warner..I know, not OEM Honda..it was a holiday, and they weren't open). I'm kinda **** about testing each step of the way...
I played with the rotor...not forcefully...gave it a hand tug, and realized it wouldn't budge with light pressure, then grabbed my FSM and read about the retaining screw. Piece-o-cake I thought, so I cranked the engine a couple times till I could get to the retaining screw, took it off, put new rotor on (also BW), re-assembled, and it won't start. The rotor spins, but the engine just won't fire and turnover. I figured it had something to do with the BW rotor, so I put the OEM Honda cap & rotor back on with the exact same results! I'm going nuts...I must have taken it on and off 6 times hoping I would spot the problem...cleaned contact points, verified springs were functioning, etc.
Any clues as to what could be wrong?
take care,
Tec
Old May 31, 2005 | 02:25 AM
Tec Nine's Avatar
Default Re: EG Not starting after cap & rotor swap?! (Tec Nine)
btt...anyone have any ideas?
take care,
Tec
Old May 31, 2005 | 02:31 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
double check your firing order. 1-3-4-2
Old May 31, 2005 | 03:01 AM
Tec Nine's Avatar
Default Re: EG Not starting after cap & rotor swap?! (Rodney)
Did that already, but it's right on the money. Thanks for the suggestion though...
take care,
Tec
Old May 31, 2005 | 05:25 PM
spooned out's Avatar
if ur not getting any fire.... try barrowing an igniter n coil......and put it in ur distributor......
Old Jun 1, 2005 | 11:31 AM
Tec Nine's Avatar
Default Re: EG Not starting after cap & rotor swap?! (spooned out)
Well, in central PA there's not a bustling H/A community for me to swap a coil, but I did test it via the FSM.
My coil comes in at 9ohm when the spec is 12-18, so I guess I need to spend $60 to see if that's my problem. Here's to hoping! I'll keep ya in the loop. And if anyone in central PA has a 1.8 GSR coil they're willing to lend me, drop me a line
take care,
Tec
Old Jun 1, 2005 | 11:38 AM
egryda's Avatar
ill bet its the igntion coil. are there any burn marks on the outside of the coil?
BigE4053
Nov 3, 2016 07:29 PM
xstalkrx
May 21, 2007 04:34 PM
JMD
Sep 29, 2004 09:46 PM
Eresuncabron
11
Aug 3, 2004 01:32 PM
Sima
May 11, 2003 07:26 AM
