b20/vtec 12.5:1 dyno...
Old May 30, 2005 | 04:34 PM
CptCorN's Avatar
Default b20/vtec 12.5:1 dyno...
Went to a group dyno event, and got a few runs in to see what shes doing... car has been "street tuned" and not dyno tuned yet...
**Ignore the 2nd run's A/F ... something got fucked up...
B20B4
84.5 mm 12.5:1 Weisco Pistons
Eagle rods
B18c1 head
Skunk 2 stage 2 cams
Skunk 2 springs/retainers
Skunk 2 adj. cam gears
Skunk 2 Intake Manifold
RC 440 injectors
J's Racing Intake
64mm ITR throttle body
Hondata S200
Chipped P28
Walbro 255lph fuel pump
Old May 30, 2005 | 04:39 PM
Steemo's Avatar
Default Re: b20/vtec 12.5:1 dyno... (CptCorN)
nice torque! it will be interesting to see what the dyno tune will squeeze out of that motor.
Old May 30, 2005 | 04:48 PM
unknown0001's Avatar
Very nice #'s
Old May 30, 2005 | 05:08 PM
CptCorN's Avatar
Default Re: b20/vtec 12.5:1 dyno... (Mr.RHTuner)
On a posative note I found out my tach is a bit laggy....I shut it down at 8200 on my tach the first 2 runs... on the 3rd one I watched the dyno... wooops...
Old May 30, 2005 | 05:39 PM
UncleD's Avatar
What header are you using?
Old May 30, 2005 | 05:45 PM
CptCorN's Avatar
Default Re: b20/vtec 12.5:1 dyno... (clean rice)
A poopy DC JDM 4-1
Old May 30, 2005 | 06:03 PM
Combustion Contraption's Avatar
There is alot of power hiding somewhere in that setup. My guess is around 15-20 more hp.
Old May 30, 2005 | 06:05 PM
BigBodySmith's Avatar
Congrats man, what kind of car is it in?? I have an Ls/Vtec 99 coupe, put down 201whp and 142ft/lbs, and it hauls ***. So in a smaller car, with a better tune, that would be pretty fun to drive. I know there is more power on tapp though. Good job!!!
Old May 30, 2005 | 06:10 PM
CptCorN's Avatar
Default Re: b20/vtec 12.5:1 dyno... (BigBodySmith)
92 Civic CX...
Old May 30, 2005 | 06:25 PM
EG6R's Avatar
Looks like youre making power past 8000RPM. Dont you just love s2s2
Old May 30, 2005 | 07:28 PM
ericrx_88's Avatar
Default Re: b20/vtec 12.5:1 dyno... (EG6R)
dam some nice numbers, hope to see you run it this year, should put down some 12 sec passes for sure. going next week, good luck
Old May 31, 2005 | 04:17 AM
CptCorN's Avatar
Default Re: b20/vtec 12.5:1 dyno... (ericrx_88)
Hopefully I'll get to run it soon... gotta fix that lean spot first!
Old May 31, 2005 | 06:32 AM
Phatch99's Avatar
that hatch must haul *** right now... nice setup!!! Let us know what u run in the 1/4
Old May 31, 2005 | 04:15 PM
CptCorN's Avatar
Default Re: b20/vtec 12.5:1 dyno... (Phatch99)
She pulls pretty good...
I gotta ditch teh shitty crush bent 2.5 and get a nice header... and maybe fab up or save up for some ITBs
Old May 31, 2005 | 04:55 PM
One Bad GeeSeeR's Avatar
nice numbers
maybe someone can answer this. why it is that a ls/vtec or gsr or itr with high compression can almost put the same numbers with a b20 vtec. does it just move the torque band lower?
carlo
Old May 31, 2005 | 06:24 PM
Brewer's Avatar
Old May 31, 2005 | 06:45 PM
KingOfQB's Avatar
Default Re: b20/vtec 12.5:1 dyno... (Brewer)
looks low for all that power to me
Old Jun 1, 2005 | 06:18 AM
Default Re: b20/vtec 12.5:1 dyno... (KingOfQB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingOfQB &raquo;</TD></TR><TR><TD CLASS="quote">looks low for all that power to me</TD></TR></TABLE>
I dont understand this statement.
Old Jun 1, 2005 | 06:35 AM
Phatch99's Avatar
Default Re: b20/vtec 12.5:1 dyno... (One Bad GeeSeeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by One Bad GeeSeeR &raquo;</TD></TR><TR><TD CLASS="quote">nice numbers
carlo</TD></TR></TABLE>
depending on elevation it varies.
Old Jun 1, 2005 | 10:55 AM
biassj's Avatar
Don't look at peak power, bigger motors make more power through out the graph.
Old Feb 16, 2008 | 08:45 PM
b-vtec's Avatar
i can not see the chart pls re post or tell me what the numbers were
Old Feb 16, 2008 | 09:39 PM
A.E Motoring's Avatar
Default Re: b20/vtec 12.5:1 dyno... (b-vtec)
**** was 3 years ago
but give u a A for searching
Old Feb 17, 2008 | 07:03 AM
Boots's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b-vtec &raquo;</TD></TR><TR><TD CLASS="quote">i can not see the chart pls re post or tell me what the numbers were </TD></TR></TABLE>
dude hasn't been on this site in like 5 months...don't think thats going to happen
all-black
K Series
Aug 6, 2009 11:39 AM
emotionisdead
23
May 13, 2005 05:42 AM
project civic
Feb 26, 2005 06:33 AM
suckafree808
65
Sep 21, 2004 04:14 PM
Simple SOHC
18
Sep 17, 2004 03:27 AM
