1st gen b16 axles in 92 civic 4 door
I have a jdm b16 1st gen motor with a y1 tranny in a 92 civic(no abs) . Ever since i had the swap my cv boots have been torn. While searching here i get lead in many diffrent directions as to what axles will fit. Instead of making this a guessing game is there anyone with experince to vouch for what axles will fit with NO complications. Which if any stock honda axle will fit correctly?(i have stock mounts that came with the swap....if that matters) I have read that 90-93 and 94+ integra and 92-95 del sol vtec axles will fit yet some people still run into problems with them being either too long or too short or break days or weeks later...sorry bout the long 1st post but this CLICKING sound is driving me nutz
...thanxxxxx
...thanxxxxx
90-93 Integra axles have a female halfshaft, so if you are using that HS you need the correct axles to match, the opposite with the 94+ they have a male halfshaft. So, if you were using 90-93 HS before, get 90-93 B series axles.
sorry, still a little unclear to me. Im not sure which HS im using now. Is there a way to tell or do all swaps come with the same one, and if so which one female or male? i have the y1 tranny if that helps n e
i belive im using the 90-93 cause there the ones that came with the swap...the only problem i have is that the axles i have now look like they tore from being to short(possibly not sure on that). Because since day one they were spitting out grease.Is this do to shitty axles givin to me (because my boy got the swap done at the same place and his axles went shortly after) or will i have the problem again once i replace them with the 93 teg axles.
92b16vx thanx for the help i grabbed the 90-93 integra b series axles, they went right in(after gettin a second pair because the 1st ones splines were messed up) If anyone is using this as info before putting in remanufactered axles check and make sure both ends splines are intact.... That blue crx i hope thats soild enuff for u haha just kidden
