prelude won't start
This is an 86 prelude 5 speed. It has been sitting in my friend's backyard for almost a year now. We charged up the battery and replaced the fuel filter. It cranks but won't start. When starter fluid is spray'd into the intake, it will start for a split second but die. Is there anyway to check and see if the fuel pump is working?
We also tried to push start with no luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilKokonut »</TD></TR><TR><TD CLASS="quote">This is an 86 prelude 5 speed. It has been sitting in my friend's backyard for almost a year now. We charged up the battery and replaced the fuel filter. It cranks but won't start. When starter fluid is spray'd into the intake, it will start for a split second but die. Is there anyway to check and see if the fuel pump is working?
We also tried to push start with no luck.</TD></TR></TABLE>
when you turn the key twice you should hear the fuel pump turn on.
lif3tak3n
Jun 24, 2014 06:00 AM
muhaMan
Jul 3, 2007 10:01 PM
