Welders
Old May 30, 2005 | 01:42 PM
AZNracerx1989's Avatar
Default Welders
http://www.mylincolnelectric.c...22423
will that welder do for welding downpipes?
Old May 30, 2005 | 01:52 PM
beepy's Avatar
Default Re: Welders (AZNracerx1989)
A stick welder? Yes, it will work, but you will be happier with a MIG I think.
Old May 30, 2005 | 01:53 PM
Default Re: Welders (beepy)
whats the diffence between stick and TIG
I bought a cheap Clarke's stick welder and it keeps getting stuck to the surface area im trying to weld
Old May 30, 2005 | 02:45 PM
arent STICK welding stronger than MIG??? and will a cheap MIG welder do fine?
Old May 30, 2005 | 03:02 PM
twinlakesterror's Avatar
Ok when stick welding and your rod sticks that means you are to close and your puddle is swallowing the rod, so you cant weld! Instead of scratching to start try just tapping and lifting up about a 1/8 inch. Stick welding i think is stronger and good luck with a cheap mig you get what you pay for!
Old May 30, 2005 | 03:48 PM
Default Re: Welders (twinlakesterror)
what is puddle
Old May 30, 2005 | 05:40 PM
Why are u considering buying welders let alone welding if you dont know what a puddle is? Does anyone else read this and shake their head?
Old May 30, 2005 | 08:22 PM
what is it???
Old May 31, 2005 | 01:52 AM
Sifu's Avatar
LMAO dude stop being a smart **** and actually go read some sites or books on welding. I just cant believe you went out and bought a welder if you didnt even reseach into it first
And NO MIG and ARC/stick welding is the same in "strength", just that ARC is more flexible. What I mean by this is imagine a bridge on a hot day, as you would imagine it would flex and sway due to the weight on top the heat. The ARC welds would allow the joints to flex more before it breaks compared to MIG.
Old May 31, 2005 | 02:50 AM
Flashmn's Avatar
Default Re: (Sifu)
I wouldnt consider STICK welders for anything than farm machinery. We welded a trailer and then some for a tractor with stick, but anything that you need to have good control on thin pipe to get it to look anything less than **** I'd take a mig.
Migging with flux core wire is as close to stick welding as I want to get in automotive stuff.
Yeah, you should of (if you already bought the welder) learn and read a bit more into things, not make a hasty decision. But if you really would of wanted to use stick, you could of gotten those inverter machines that have scratch tig in them.
Modified by Flashmn at 4:01 AM 5/31/2005
Old May 31, 2005 | 04:27 AM
barszcz's Avatar
Default Re: (Flashmn)
seriously, not trying to jump on the bandwagon with everyone else... but just because you can buy a welder does not make you a weldor. i have been doing for a long time and have seen several cars come into my shop that i would not drive around the block let alone down the race track. LEAVE THE WELDING TO SOMEONE WHO IS A PROFRESSIONAL! or wait until you have improved your skills. and by all means pick up a book and read about what it is you are buying before just buying a welder and then asking if it will work with your application.
Old May 31, 2005 | 05:29 AM
sleep's Avatar
wait a min... you guys didn't know that everyone that owns a welder is a welder?????
geez...
Old May 31, 2005 | 07:34 AM
Default Re: (barszcz)
u BUY a welder so u can LEARN to weld
i returned my stick welder... maybe ill get the lincoln electrics AC-225 stick welder or go for a cheap MIG on ebay..
what do you guys think?
http://cgi.ebay.com/ws/eBayISA...&rd=1 <-- like that MIG
Old May 31, 2005 | 08:17 AM
neogenesis2004's Avatar
Default Re: (AZNracerx1989)
You need to take their, and my advice I gave you when you IM'd me. Go to your local barnes and noble or borders books and read some welding books. At least browse them so you can get terminology and basic technique. You could buy them or just be cheap and buy some coffee there and sit down and read it for free like me. Either way if I were you I wouldnt pay anymore money until I knew what I needed.
Old May 31, 2005 | 11:22 AM
Sifu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZNracerx1989 &raquo;</TD></TR><TR><TD CLASS="quote">u BUY a welder so u can LEARN to weld
http://cgi.ebay.com/ws/eBayISA...&rd=1 &lt;-- like that MIG</TD></TR></TABLE>
Dude its the same with a car, you dont buy it then learn to drive it just like that. Before actually doing so you have to learn the basic concept of it like how the road code works. Sure you maybe learn how to actually drive the car but the concept of actually being on the road before that you have to learn.
Old May 31, 2005 | 12:57 PM
ManBearPig4silly's Avatar
Do some more reading in this forum. You dont buy a welder and just learn to weld it takes time and practice. At least make friends with someone who has welded before.
sikevin726
Aug 5, 2008 07:14 PM
stackz
Welding / Fabrication
23
Jan 5, 2006 09:44 PM
Formula Racing
11
Oct 5, 2004 08:16 AM
jond
Mar 22, 2002 06:44 AM
