Cam gear adjustment
Old May 30, 2005 | 01:16 PM
B20_SI_CRX's Avatar
Default Cam gear adjustment
I have a milled head of.028 and high compression valves and 2 layer head gasket and I just got stage 1 skunk2 cams and jg cam gears and I was wondering how I should do the cam timing on the dohc?
Old May 30, 2005 | 05:17 PM
B20_SI_CRX's Avatar
Default Re: Cam gear adjustment (B20_SI_CRX)
Anyone?
Old May 31, 2005 | 12:52 AM
B20_SI_CRX's Avatar
I will ask one more time since my post has now made it on the 3rd page.
Old May 31, 2005 | 01:56 AM
ritalin
Guest
Posts: n/a
I'd start with advancing intake and retarding exhaust to help with cylinder filling.
Old May 31, 2005 | 06:29 AM
B20_SI_CRX's Avatar
Default Re: (ritalin)
Ok cool
Old May 31, 2005 | 04:12 PM
B20_SI_CRX's Avatar
Is that more like low end or top end though?
Old May 31, 2005 | 04:16 PM
Crx Jimmy's Avatar
you cant just guess, you have<U></U> to put it on a dyno, every engine is different, what will work for you wont work for someone else even using similar setup, i wouldnt trust the butt dyno on this one, ive seen it be decieving in these cases
Old May 31, 2005 | 04:45 PM
B20_SI_CRX's Avatar
Default Re: Cam gear adjustment (Crx Jimmy)
ok well keep it at 0 then for now cuz right now its 2 degrees advanced on the intake and 2 degrees retarded on the exaust
Old May 31, 2005 | 05:28 PM
B20_SI_CRX's Avatar
Well I tried the +2 intake and -2 exaust and to me 0 degrees on both cams feels better so I dont know.
Old May 31, 2005 | 10:22 PM
Suck my DX's Avatar
stop ****** with it..u dont know what ur doing
Old Jun 1, 2005 | 02:15 AM
limpy's Avatar
Default Re: Cam gear adjustment (AMPYR_one)
since the head was milled both of the cams will be retarded just a little. but yeah... take it to a dyno and have them adjust them.
Modified by limpy at 2:20 PM 6/1/2005
Old Jun 1, 2005 | 11:40 AM
B20_SI_CRX's Avatar
Default Re: Cam gear adjustment (limpy)
Ill **** with what I want and when you mill a head it retards the timing...lol
Old Jun 1, 2005 | 01:20 PM
limpy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20_SI_CRX &raquo;</TD></TR><TR><TD CLASS="quote">Ill **** with what I want and when you mill a head it retards the timing...lol </TD></TR></TABLE>
damnit... i was thinking about it and thought i had it backwards. lol..... fixed
Old Jun 1, 2005 | 01:54 PM
Steemo's Avatar
I think you are a <U>retard</U> for messing with <U>advanced</U> cam gears. You CANT just play with them till something feels right. You need to take that thing in and get some information from a data logger. You are going to screw up your motor by "playing" around with them like that. Dont be cheap take it to a shop slap it on a dyno and get that thing dialed in.
Old Jun 1, 2005 | 05:30 PM
Suck my DX's Avatar
Default Re: Cam gear adjustment (Steemo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steemo &raquo;</TD></TR><TR><TD CLASS="quote">I think you are a <U>retard</U> for messing with <U>advanced</U> cam gears. </TD></TR></TABLE>
HaHaHaHaHaHa!!!
Old Jun 2, 2005 | 01:19 AM
B20_SI_CRX's Avatar
yeah retard I am going to take it to a dyno and wow I sure messed up my motor...LMFAO
Old Jun 2, 2005 | 02:44 AM
Twilight's Avatar
Just put the stock values and get the car tuned in dyno.
Old Jun 2, 2005 | 03:29 AM
B20_SI_CRX's Avatar
Default Re: Cam gear adjustment (Twilight)
Ya thats where I am leaving it until dyno tuned but what I was really wanting to know, is how to adjust the gears for top end power?
Old Jun 2, 2005 | 03:48 AM
Kaan's Avatar
Loved
Community Favorite
keep them at factory spec till you get the dyno and tuner. and never for get your ignition timing :-P
and this is why i love SOHC lol
if you go to a good engine tuner with a reliable dyno, they'll know where to start and should be able to pull out more power. they should run a wide band (yes even on yur NA car)... if you have a stand alone, make sure they deal with that brand, if you have a hack... well most people can use a hack.
Old Jun 2, 2005 | 01:03 PM
B20_SI_CRX's Avatar
Default Re: Cam gear adjustment (MMsportsRexSi)
Ya I know all that..lol
Mad Cow Disease
Jun 1, 2009 05:21 PM
milano2kdc2
Sep 1, 2005 07:52 PM
cjames235
Feb 18, 2004 09:04 AM
takeheed
Aug 28, 2002 07:40 PM
Eeepers
Apr 4, 2002 08:34 PM
